Old 20-09-2009, 11:52 AM   #1
daniel_rossy
AU Falcon
daniel_rossy's Avatar
Default Advice Please, Wanting to upgrade my cam in my AU
Hey everyone,
I'v been thinking about upgrading my cam for a while, now I'v been told by a cam dealer that i need a aftermarket ecu if i alter my cam in my au.
I don't want anything to lumpy, just something more than stock, maybe stage 1 or 1.5, nothing ridiculous.
Would you recommend doing this or just throwing the cam straight in?
Any advice would be greatly appreciated thanks ,
Rossy.
daniel_rossy is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 01:36 PM   #2
Fordfan4u
Your in Vic, speak to GnD or Bluepower.. Could speak to JMM but you'd be wasting your time and money. I'd highly recommend a Surecam.
Baring in mind, after a cam change, something small you wont need to have a tune but it's advisable to get the most out of it. Add a vernier gear to.
Officer: You've been drinking, i'll move your car...
Me: No worries, thanks, just so you know it has a brass button clutch.
Officer: [stalls] I cant find the button?
Me: What button?
Officer: The button for the clutch!!!
Me: [laughing so hard it hurts]
Fordfan4u is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 02:50 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Ive always wondered why people talk in stages? As in, you here all the commodore owners go on about stage 3 heads, stage 4 cam. I have no idea what they are on about.
Talk to surecam, tell them what you have and what you want, and they will please you better than the new Rammstein filmclip.
So what stage cam do I have, lol. And what stage was Stiddy's? A stage 12?
MD Mondeo - For the family
NP Pajero - For the adventure
Old 20-09-2009, 04:11 PM   #4
Stattic
Stattic's Avatar
yeh i have NFI what stage things are.. i always assumed it was a manufacturers way of how extreme it is lol :P
and yes... i am in vic and i got a surecam and i am very pleased with it, just tell him what you want and he will grind you a cam to perfectly suit your needs
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 06:41 PM   #5
51OAU
51OAU's Avatar
i personaly think, putting a "bit bigger cam then standard" in is pointless, spend your money on other things. If u want power u are better off going all out, but as most people have said, speak to Surecam $565 i think it is to your door.
51OAU is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 06:46 PM   #6
The Monty
Just slidin'
The Monty's Avatar
Best bang for buck mod is diff gears, hands down.
Old 20-09-2009, 08:58 PM   #7
daniel_rossy
AU Falcon
Okay sweet thanks for the help!
I'll give Surecam a shot.
Old 20-09-2009, 09:25 PM   #8
Stattic
Stattic's Avatar
youve got some decent mods already, would be great to see another quick au on the forums, your car will be a beast with a cam in it
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 20-09-2009, 10:13 PM   #9
daniel_rossy
AU Falcon
Thanks pal
I'm keen on taking it to calder and taking it on the 1/4 after i'm finished,
i'll start a workshop build and keep everyone informed on how she goes
Old 20-09-2009, 11:07 PM   #10
Stattic
Stattic's Avatar
sounds good mate!
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 21-09-2009, 01:36 AM   #11
mik
mik's Avatar
the stage thing was a description of where the power starts and stops,
stage 1 power from 1800 to 4800 ideal for towing ...normal idle
stage 2 power from 2500 to 6000 slight lope more power in higher rev range still suitable for street
stage 3 lumpy idle valve train work needed 3500 to 7000 suitable for track
it went something like that from memory, the figures i just made up but you get the idea.
Old 21-09-2009, 07:34 PM   #12
azza11
azza11's Avatar
Stages should have gone out with Noah and the Ark. Talk with a cam grinder, Watso, Camtech or Dean Tighe, they have the masters and will grind one to suit. Cam also depends on type hydraulic or solid or roller cam. What you think is a big cam and what realy is a big cam is a big difference. My clevo cam by Dean Tighe was a 248/258 duration and 596/606 lift @50 on 108 lobe centres. This is a biggish cam for a clevo. A big cam would be 280 odd duration flat and 660 lift and higher. My 557 BBF will be a solid roller and over 700 thou lift. Trick Manswetto have a 950 lift roller in the capri. Thats effin huge. Let us know. What about a xr6 grind?
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now.
*****XR PARTS WANTED*******
azza11 is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 08:09 PM   #13
The Monty
Just slidin'
The Monty's Avatar
A big cam for an AUi6 isnt 660thou of lift. The difference between a big cam in a clevo and an i6 is quite big. Hell, look at big cams for a Skyline i6 and the profiles for it will be completely different to what is a big cam for us, you have to compare apples with apples.
Old 21-09-2009, 09:28 PM   #14
pstap
Intimidator AU3 XR8 347
pstap's Avatar
daniel i got 200rwkw out of my au3 xr8 motor unopen. i put a good set of headers on , 2.5 in twin pipe std cats ,aftermarket ecu is a must , try and get more air in the air box , use k&N air filter ,you said you want to up grade your cam a little ,go and get a au3 xr8 220 from ford, i got 200rwkw with a good tune. what head are on your au2 motor ?
AU3 XR8 347
500hp
Intimidator
Motor built by John Macchione
www.ultratuneerina.com.au
pstap is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2009, 09:39 PM   #15
Stattic
Stattic's Avatar
i think we are talking 6 cylinders here lol
and no i dont think he will be needing an aftermarket ecu
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 21-09-2009, 11:38 PM   #16
Fordfan4u
At the end of the day it comes down to what you want, everyone is raising valid points though. Well almost.
Monty is right in saying diff gears are one of the best mods. Surecam's imo best on the market. (Monty, stid had the biggest possible cam Surecam could give him, no sure on specs, but it would barely idle and didn't have much til 3500-4000 then it was white knuckled ride)
Cam/head/valve train is where you will gain alot of power from the I6 if its done right. Especially if you have a tuner who knows what he's doing.
Hoppers Heads in Vic have a 175rwkw head and cam package at the moment for a silly price, not much over $1000 from memory.
If you want a quick car, everything has to be 'matched or balanced' Ie no point getting a cam with a power band from 1800-3500rpm if you have a 3000rpm stall.
There is a vast range of products for these tractor motors these days, choose wisely.
Me: What button?
Old 22-09-2009, 12:35 AM   #17
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
a custom tune and tuning tool is a must imho if a cam other stock is fitted. otherwise i dont reckon you'd get the full benefit of the cam. i was told a cam with a tuning tool goes hand in hand when it comes to au's
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2018 Hyundai Santa Fe Highlander
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2009, 12:45 AM   #18
Stattic
Stattic's Avatar
yes, hoppers cylinder heads are about 10 minutes away from me and it is quite cheap
you still need to factor in tuning, a tuning device, got to give them your head and how do you know those figures are reliable? for an I6 to make that much power im fairly sure the cam would be quite aggressive so youd need a high stall and trans cooler to suit
also they specify i believe EA-EL.. im sure if it was compatible with the AU they would say so but who knows? i havent called them so i dont know but it does look quite appealing
but honestly, if it was that easy to make 175rwkw, everyone would have done it by now
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 24-09-2009, 09:50 AM   #19
daniel_rossy
AU Falcon
Cheers everyone,
Yeah looks like i'll be tuning her once i get the cam,
at the end of the day its only a few more dollars more and it will make it run better and harder.
