Old 30-08-2009, 04:41 PM   #1
Orchadis
Default Driver side air vent
Hey everyone.
I just upgraded from my 91 Laser to an 02 Focus CL. First of all, wanna say Loving it. It handles so nice, just wants to fly around corners just a tid bit quicker too
I have (had) two problems that I need to fix. The first I have fixed - The cigarette lighter fuse was blown, couldnt find the fuse box - Thanks to Tj for the awesome description in the other thread of how to get to it behind the glovebox .
The next one I suspect will be a little harder to fix. The drivers side air vent does not work. No air comes out, no matter what setting it is on.
Any suggestions or thoughts? :
Oh just a little tid bit too, well - giving into peer pressure I put a pod on it, um lol its just silly... but in all seriousness I ordered a rear swaybar :hihi:
Question - Has anyone put on a front strut brace? For my vintage they only come for the 2.0L Zetec -> Im guessing that things are arranged a little differently as it looks like the fusebox will get in the way and there is verry little bonnet clearance.
Orchadis is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2009, 09:59 PM   #2
BlackLS
yum
Sounds like the flap on the drivers vent is broken.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire
250,000kms.
BlackLS is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2009, 10:46 PM   #3
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
The xr5s have a strut brace.
However, being a completely different engine it's possible that it wont fit.
If you check out this thread:
http://www.fordforums.com.au/showthread.php?t=11270595
That dude is wrecking a whole XR and provided it isn't damaged you might be able to pick it up cheap.
Failing that, if you're willing to hand over the beans, European parts have one :
http://www.european-parts.net/catalo...roducts_id=817
Funnily enough it says it will fit all MKII foci including the XR, so perhaps picking up that xr brace isn't a silly idea.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2009, 12:07 AM   #4
melbzetec
Old enough to know better
melbzetec's Avatar
Except a 2002 CL is an LR Focus.
There are strut braces available, but they provide little assistance.
The LR Focus is a very stiff chassis as it is, and there is little to be gained by linking the strut towers. From memory, the Focus was something like 30% stiffer than a WRC Escort.
If you must have one, here is a start:
http://focus.c-f-m.com/index.asp?Pag...S&Category=305
IMHO you'd be better off upgrading the springs and/or Anti roll bars (Eibach are good) than spending money on a strut brace
Regarding the air vent, if the flap is stuck, you should be able to check by pulling the vent straight out: here's a how to:
http://www.focushacks.com/index.php?modid=9&ht=Removal of vent pieces
And welcome to the Forum!!!! The LR Focus is a great car. I'm glad you're already enjoying the handling
Old 31-08-2009, 04:31 PM   #5
Orchadis
Thanks for all your input guys!
Regarding the strut/support issues - all make sense. Like I said I'm going to go for rear sway first up, the strut was just a question as my friend and I looked at it and thought that the fusebox was in a place - very little clearance for a strut.
Thanks melbzetec for the link on how to get the air vent out - I popped it out in about 30 seconds but the flap wasnt the problem! Pulling the cent out however did lead me to discover the problem. I turned the heater on stuck my hand in there and felt around for where the hot air was coming from... and I found it!
Took the kick panel off so I could pop it back into place properly... hope it doesnt come loose again...
The kick panel brings me to another question, wtf is this?
hrm - I seem to be failing at trying to resize these images...
Old 31-08-2009, 05:48 PM   #6
BlackLS
yum
OBDII Diagnostics port.
2005 LS Focus LX
250,000kms.
