Old 28-05-2008, 06:49 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Why do they call it the clock spring?
Just spent an hour or so changing the "clock spring" on the wagon and I have to wonder why it's called a clock spring in the first place. A clock spring is a spiral wound flat spring so I expected to see a flat tape type cluster of wires that spiraled round under the airbag somehow. What I found was nothing like that. It's 2 plastic disks pressed together with one fixed to the column and the other fitted over the steering wheel shaft so it rotates with the wheel. I assume there's the usual copper ring and brush type setup inside the discs to close the airbag circuit. None of this is remotely like a clock spring in any way that I can see so why the name.
On the plus side, once I'd borrowed the right torx bit to get the airbag off it was easy enough to change and only cost $65 to get a replacement part from the local wreckers.
Bushbasher
MINE- AUII Forte
Old 28-05-2008, 07:07 PM   #2
tufLTD
tufLTD
tufLTD's Avatar
The clock spring is inside the plastic discs.
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 07:45 PM   #3
fairmont1998
fairmont1998's Avatar
tufLTD is spot on, and not only are the airbag wires in there, the horn, cruise buttons and radio buttons are all connected through the clockspring. Something you won't be able to achieve with copper rings and brushes.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 09:43 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
So whats the difference between the "clock spring" and a Slip Ring setup?
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 10:27 PM   #5
fairmont1998
The main benefit of a clock spring is you can run more wires through the restricted space available behind a steering wheel. Also there are no contacts or brushes, the wires in them are hard wired or connected by plugs.
Here is a pic, taken from www.timgilles.com that shows the ribbon cable inside the clock spring. The cable is long enough to allow enough turns left and right without straining the ribbon.
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 29-05-2008, 07:36 AM   #6
InfernoSR
InfernoSR's Avatar
Ah... thanks for that... now i know
Old 29-05-2008, 06:14 PM   #7
Bushbasher
Bushbasher's Avatar
Thanks for that, that's what I was expecting to see when I did the job.
Bushbasher
MINE- AUII Forte
Old 16-08-2009, 12:07 PM   #8
jimbobpro
how do you change the clock spring any help would be grate thanks guys
jimbobpro is offline   Reply With Quote Multi-Quote with this Post
