Old 03-08-2005, 01:16 AM   #1
TX5_AX
Low EF
TX5_AX's Avatar
Default car revvving itself at lights
when i start my car for the first time it idles at 750 which is fine, but later down the road when i pull up at the lights in neutral it starts going spastic... the taco will go down to 600 then bounce up to 2300rpm and just keep boucing till after bout 15 seconds it will just sit idleing on 2100.
anyone noe wtf is goin on?
cheers
TX5_AX is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 01:34 AM   #2
MITCHAY
Mmm weird when my car is cold it will idle at 1500 and then go to 750 when warm. Very strange and im guessin somethings up with the ISC (Idle Speed Control) valve. Its regulates the warm up idel and is meant to maintain idle at set values. Sorry cant be much help than that.
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2005, 11:22 PM   #3
TX5 GT
Sold one of the Telstars
sounds like you need to clean the EGR valve.
if you had a AT/AV telstar i could tell you exactly how to do it but im not sure if AX's even have that valve, but if it does id put money on it.
89 626 GT-TURBO
CAI - SUNROOF - ADJUSTABLE SUSPENSION - SOUND SYSTEM - CRONOS FRONT END - 4SPEED AUTO - 15PSI - EXHAUST - FRONT MOUNT COOLER - HEAVY DUTY BANDS - TORSEN LSD - DYNOED AT 145KW ATW @ 6000RPM everything after 4 speed auto is a typo
TX5 GT is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2005, 03:54 PM   #4
TX5_AX
Low EF
TX5_AX's Avatar
can u give me some info in the EGR valve.. wot is it?
ive been asking around and most people are saying idle speed control as michay said
Old 08-08-2005, 11:20 PM   #5
TX5 GT
thats what every1 told me, until someone said to clean the EGR valve and guess what, it fixed it.
The egr reuses exhaust so there is less emissions and uses less fuel. I cant really tell you anything more but id find out where it is and clean it out with carby cleaner and see what that does, $5-6 is at stake
89 626 GT-TURBO
Old 15-08-2005, 11:15 PM   #6
TX5_AX
Low EF
TX5_AX's Avatar
i dropped the oil, new oil filter, did a coolant flush and its seemed to have fixed it.
runs smoooth as, without a glitch.
going to get a falcon now \m/
