20-07-2009, 12:29 PM | #1 | ||
low wagooon
As the thread states has anyone here removed one before? Mine died on sat and i am unable to put my window up. I ordered a new one this morning and just wondering how you remove it all.
Thanks AJ
Webby
S2 AU XR6 UTE |
20-07-2009, 07:20 PM | #2 | ||
FORD4LIFE
id be interested to know how this is done too. mine are getting slower everyday.
:evil3: AUII XR8 UTE. BLACK. MANUAL : : out: HSV " I DONT WANT ONE" :monkes: |
20-07-2009, 07:24 PM | #3 | ||
Narooma blue XR8 ute
mine sticks about 2/3's of the way up will a new reg fix it ?
20-07-2009, 07:25 PM | #4 | ||
you need to lube your channels, the rubber goes dry and the glass sticks to it
03 BA Pursuit Blue Power Racing Developments (03) 93053000 Ray Prescott Auto (02) 49902488
20-07-2009, 07:46 PM | #5 | ||
Flairs - Truckers Delight
99 times out of 100, it's nothing to do with the reg, get some silicone spray on the channels and dig out your switches and douse em in carby cleaner, and give me some rep points cos i just saved you a whole lot of effort and expense.
20-07-2009, 09:12 PM | #6 | ||
If cleaning doesn't help they do wear out, they are an electric motor driving a wire around plastic pulleys, the wire can break, the pulleys wear out, the wire cuts the pulley in half, the spot weld breaks and the whole things bends, the electric motor can burn out there are many reasons
Basically take door trim off Remove window from 2 plastic bits clipping it to glass Use a screwdriver at each end and lever white tabs out while lifting glass up Window needs to be 3/4 down to get acces for this Push window UP to top so glass is out the way, maybe tape up as they sometimes fall down and chop your hands A couple of nuts to undo motor A couple at top of the centre rail and a couple at the bottom Unplug the motor Remove the thing, a bit fiddly but it will come out Reverse to put back together |
20-07-2009, 10:20 PM | #7 | |||
If its a front window, i'd pull the glass, really easy to do, never done a back window ute's don't have them, and really lube up the channels before you put it back together.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
20-07-2009, 10:32 PM | #8 | ||
Mine doesn't just stick it drops at the front & I have to lift it then it will go the rest of the way up on it's own
21-07-2009, 12:19 PM | #9 | |||
low wagooon
Webby
S2 AU XR6 UTE |
22-07-2009, 09:28 PM | #10 | ||
OzEcruisers PRESIDENT
bugger
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
22-07-2009, 10:32 PM | #11 | |||
low wagooon
New window reg turned up today, fitted it quite easily cleaned the switchs while i was going so all is well. Bit of an effort after working 13 hours but got it done after a bit
Webby
S2 AU XR6 UTE |
23-07-2009, 09:10 AM | #12 | ||
Did you take pics to help other members or did you just use them for info again
23-07-2009, 10:04 AM | #13 | ||
Workshop & Performance
Mines not AU but has anyone tried a aftermarket one? Im not sure it could be any worse than the original Ford part....
When close is good enough and the 6 MPS in the driveway has FoMoCo written all over the place. Xr5 for sale shortly...just not a hatch guy |
23-07-2009, 12:16 PM | #14 | ||
I have an aftermarket one fitted into my drivers door on my EF - no problems
Apparently there are a few different versions of the aftermarket ones and one of them is a real dodgy one that will fail again :( obviously its the cheapest $$ one - unsure the brand name
