20-07-2009, 06:27 PM | #1 | ||
Flairs - Truckers Delight
Sorry to be a nong
but what sort of screw type thing holds in the speakers? What sort of tool do i need to get them out? /inb4 pliers
20-07-2009, 06:31 PM | #2 | |||
You can't stop the signal
Memory says that they are a male torx screw, hence a female torx bit. But they may have more points than that. Been ages since I've seen them
Either way a 5mm socket works well in removing them. I may be wrong on the size thought. They may be 4mm or maybe 6mm but a small sized socket does work. Cheers
20-07-2009, 06:47 PM | #3 | ||
ah sweet as. small socket it will be. thanks mate!
20-07-2009, 06:54 PM | #4 | ||
GT-P With An Ego
It's called an E type socket. Good hardware stores will have them.
Superroo is right, it's the other 'sex' of a torx head.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw. Ford Performance Club of ACT |
20-07-2009, 06:55 PM | #5 | ||
wow!
right! thanks mate
20-07-2009, 07:19 PM | #6 | ||
GT-P With An Ego
I've only ever used the one. E6.
20-07-2009, 07:47 PM | #7 | ||
ROCKING THE EL FUTURA
mate use a 5mm socket does the job i did not only two days ago worked great.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
20-07-2009, 08:10 PM | #8 | |||
Audi S3
20-07-2009, 08:13 PM | #9 | ||||
5mm socket --- I'll bet my balls it's cheaper than a set of E-type sockets!
20-07-2009, 08:28 PM | #10 | |||
AsIzZy |
20-07-2009, 09:02 PM | #11 | ||
Pliers work as well
They are not real tight |
20-07-2009, 10:17 PM | #12 | |||
20-07-2009, 10:24 PM | #13 | ||
Yep, as previously stated 5mm socket does the trick!
http://aufalcon.com/THR347 |
20-07-2009, 10:52 PM | #14 | ||
AFF Whore
Fantastic news, that shall help me out this coming weekend, now off to troll the old threads for making up 6" speaker spacers for the front
