Old 31-10-2008, 12:58 PM   #1
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Default FG Bpr Cai $650
Here are some pictures of our FG airboxes.
$650 from any BPR Dealer
The FG Airboxes cover the full range of cars such as
6Cyl, Turbo and Boss 290/315.
FG 315 Twin throttle body intake pipes also sold with this kit for $110 extra.
We have Dealers Vic/SA/ACT/QLD/WA and if you are located outside our dealer network, we will post directly to your door.
All orders please call us on 03 9305 3000 to place your orders or Via PM
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2008, 09:51 AM   #2
Cobra
Bear with a sore head
Cobra's Avatar
What's the performance gain been on the FG? Has it been on the same level as the BA-BF for this type of mod? It appears to be common knowlege now that the gap under the headlight and foglight area isn't as great as the BA-BF and therefore the airbox doesn't get the desired amount of air required (in theory). I really hope that this type of airbox can be retained for the FG range, as the gains seen on the B-Series cars were very good. If you guys have any before and after dyno sheets, they'd be a great way to dispell some myths.
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2009, 10:17 PM   #3
ADSXR8
Hey Guys
Just reading this and seen there is no response. I am sure it was just an oversight. Would love to know the answer.
Thanks
Adam
1994 XR8 Sprint
ADSXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 09:38 AM   #4
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi mate,
on a "restrictive" car, ie totally stock with no exhaust mods, it splits hairs between 4-6rwkw on a 290 XR8
on a "massaged" car, say something with a nice exhaust, we have seen 10-20 on the same setup.
One big benefit we see is that the car is always on tick, as the warm air from the thermo fans cannot enter the BPR box, but they DO enter the 2nd inlet on the FG snorkel, and of course, bigtime throttle response!
Hope this helps
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 12:11 PM   #5
Theo@BluePower
Bluepower
I have had heaps of questions for more pics of the FG BPR CAI..
I took some pics of a car yesterday to post up...
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Old 30-04-2009, 12:25 PM   #6
LG
LG's Avatar
Daim they look good! Very quality finish! I'd still be interested on an AU6 one, when the time comes.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2009, 12:26 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Looking forward to getting mine and once it's installed I will post a few pics (mines an XR8).
RAM 1500
Old 04-05-2009, 10:31 PM   #8
b2tf
b2tf's Avatar
Mine is installed and far out does it make a great sound! Be interested to see how it goes tomorrow morning on the way to work with the colder air.
Thanks to Chris and Theo too for assisting me with installation over the phone.
RAM 1500
Old 04-05-2009, 11:12 PM   #9
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Originally Posted by Bluepower
Hi mate,
Is this with the Ford air filter? Could you get a few more killawasps with a K&N filter?
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 01:42 AM   #10
GTpilot
FG GT 5.4 w/ additions!
GTpilot's Avatar
What is the neck size on the filter is used on the GT?
The beginning of the air intake looks to be same as the standard one (approx 90mm??)
Can you pls explain to me why this is the case when the TB is a twin 60mm (120mm total) setup. I'm sure there is a reason.
I have been looking at this on my GT and cannot figure out why FPV have done this as std, even you guys look to have stuck with this setup too. I'm no guru like you guys, but to me it seems a waste to restrict 120mm of intake volume at the TB down to 90mm at the filter.
GTpilot is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 08:39 AM   #11
b2tf
b2tf's Avatar
The K&N in the Bluepower box is a 4" diameter one - it won't restrict airflow on anything less than maybe a jet aircraft. It's enormous!
RAM 1500
Old 06-05-2009, 07:04 AM   #12
Micksxboxmods
BF FPV GT-P Goodness.....
Micksxboxmods's Avatar
...therefore it would as jet aircraft dont run air filters ;)
On another note...How much are the twin TB plenums for a BF(imagine FG will fit on)??
Micksxboxmods is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2009, 10:31 AM   #13
paulie0735
paulie0735's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Sorry mate, don't want to come across as a smartarse but your assumption that 2x60mm openings is bigger than 1x90mm isn't actually correct, in fact the opposite is true. The 90mm hole is actually bigger than the 2x60mm holes. It’s a common mistake so don't feel bad.
Area of a circle is calculated as
Pi (3.14) x radius of the circle squared.
So, if the intake pipe is 90mm than the radius is 45mm therefore 3.14x45x45 = 6,358 sq/mm. Where as a 60mm intake pipe has an area of 2,826 sq/mm (3.14x30x30), so 2x60mm intakes has a combined area of 5,652 sq/mm.
Hope that helps put your mind at rest.
paulie0735 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2009, 02:15 PM   #14
GTpilot
GTpilot's Avatar
: See, I knew there was a logical explanation!!
Old 06-05-2009, 02:26 PM   #15
paulie0735
paulie0735's Avatar
The airbox looks good though, I'm about to trade the XR5 in on a GT-E
Old 06-05-2009, 03:23 PM   #16
WASP
Whipple Induced
WASP's Avatar
Nice work guys. It's looks the business and no doubt makes a good thing even better.
Colville
“You can't build a reputation on what you are going to do.- Henry Ford”
WASP is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2009, 02:29 PM   #17
ADSXR8
Hey paulie, have you got your eyes on the demo?
1994 XR8 Sprint
Old 09-05-2009, 08:06 AM   #18
paulie0735
paulie0735's Avatar
yeah, but my accountant is not impressed!! lol. The change over on the Mondeo is a financial disaster, I think they have somebody else looking at it to so might let it go and re look again in 12 months, I'll know more next week I guess..........
Old 25-05-2009, 01:01 AM   #19
Redrum
Force Fed Fords
Redrum's Avatar
Chris/Theo
In regard to the BPR airbox is there a lot of induction sound fitting this to the I6T's?
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2009, 08:59 AM   #20
Theo@BluePower
Bluepower
Originally Posted by Redrum
Chris/Theo
Yes with the FG turbos we have fitted a few so far...
You can hear the induction noise a lot more but the muffler in the intake still keeps it down...
We are waiting for a good replacment kit to come out to get rid of the muffler and the hot side piping to start pushing these cars a bit more...
Bluepower website
03 9305 3000
Old 25-06-2009, 02:44 PM   #21
09 FG XR8 UTE
G day guys
Im still learning bout CAI's at the moment. I looked at the SS inductions Fg growler kit and im getting a lot of bad feedback and a lot of intelligent people have pointed me in this direction, only thing is with the BPR CAI, where are the intake holes? When u look at the ss one u clearly see the hole on the top when u open the bonnet, however looking at BPR thumbnails, I cant see where the actual air is taken in, and well Im a bit blonde and confuzzled atm. Anybody help me as Im keen to purchase BPR Intake soon.
cheers BPR team
09 FG XR8 UTE is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 04:46 PM   #22
willsace
Finally have a boss again
willsace's Avatar
Originally Posted by 09 FG XR8 UTE
G day guys
cheers BPR team
the BPR CAI draws air in from behind the head light, so you sort of wont see any intake holes so to speak
EA S Pac with EB XR8 driveline
willsace is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 07:04 PM   #23
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
G day guys
cheers BPR team
As Willsace said behind/under the headlight there is a 4"x6" hole which draws air through the lower opening on the bumper.
You wont go wrong with the BPR cai, work a treat.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 08:59 PM   #24
09 FG XR8 UTE
awesome , Ive heard that with BA/BF'S U should replace the oil pump gears prior to any mods including CAI's. Is this the same with FG's or have they rectified the problem? Otherwise il be doing them at the same time as the BPR, which means more saving...lame :(
Old 26-06-2009, 01:39 PM   #25
09 FG XR8 UTE
So will the twin throttle body kit fit the FG XR8 too, I know its common sense and a very blonde question, but just wanted to double check? and does the FG BPR CAI kit include the filter n all? or just the box?
Old 26-06-2009, 02:00 PM   #26
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi mate,
only in a high RPM situation would we look at replacing oil pump gears, on the street with a sensible rpm limit it will be fine.
Chris
Old 06-07-2009, 10:41 PM   #27
grafpak
Talking
wheres the 4"x6" hole ???i could only find a small round hole about 2"in diameter....we are talking fg's here?
and a question for the bluepower guy's -have you thought about adding a side vent to reuse the origional scoop as it seems to suck plenty of air?
and as for thermo fan heat at the rear vent what about covering with 4"hose or even sell new scoops without the rear vent???
just some feedback...
ps.. how did the origional ba gt pods flow i've seen a few of these wiyh a typhoon top scoop added?
.cheers..dc..
grafpak is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2009, 09:18 AM   #28
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi dc,
we have played with side entries, and they take a diversionary role in getting airflow into the box - you end up with a disturbance of laminar flow, which makes the car far more inefficient.
In laymans terms, by adding a side entry to the box you create turbulence around the mandrel inlet tube. Laminar flow is critical in getting these engines to make big power.
Our FG is now making 419rwkw 9psi of boost, and if the airbox was a restriction we would have seen that on the dyno, lid on, lid off, pod only, the best results are always with our stock setup as installed.
All these idea's are "tried" and "tested" on our road cars, if they dont make the cut, they are not used.
Regards
Chris
