Old 07-06-2009, 01:31 PM   #1
2fords
Default Over Heating Issue, Au Fairmont
HI
I AM ONLY A NEW MEMBER AND HAVE A S1 aU UTE AND A S2 FAIRMONT WAGON. BOTH ARE 4.0L
ON MY WAGON IT HAS RECENTLY HAD A COOLANT FILLER TANK REPLACD AND HAVE HAD A OVERHEATING PROBLEM EVER SINCE.(WEIRD)
I THOUGHT IT WAS A WATER PUMP ISSUE,OVER HEATING AT THE TRAFFIC LIGHTS ETC) SO I REPLACED THAT AND THE 2 SPONGY RAD HOSES ASWELL. THIS STILL DIDNT SOLVE THE PROBLEM
IVE ELLIMINATED A BLOCKED RADIATOR, UPON PLAYING AROUND WITH THE THERMO FANS IVE FOUND THEY DONT COME ON AT ALL,
IVE TESTED( BY HARD WIRING) THE FANS , THEY WORK
CAN ONLY ASSUME IT EITHER A TEMP SENSOR OR A FAULTY RELAY SOME WHERE
NORMALY THE CAR IS ON "O" ON THE TEMP GAUGE
ALSO THE THERMO FANS DONT COME ON WIH THE AC ON (WHICH I HAVE HEARD SHOULD HAPPEN)
MY QUESTION IS
a, WHERE IS THE TEMP SENSOR? IS IT HARD TO GET TO?
B, COULD IT BE A FAULTY TEMP SENSOR EVEN IF MY GAUGE I WORKING?
C, WHICH RELAY RUNS THE THERMO FANS?
CURRENTLY I HAVE HARD WIRRED THE FANS TO A SWICH SO I CAN TURN ON IF IT GETS TO HOT, WORKS WELL BUT I WANT THE ORIGINAL PROBLEM FIXED
ALL HELP WOULD BE MUCH APPRECIATED
THANKS
2fords is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2009, 01:54 PM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Although i am unable to answer your above mentioned questions, i simply suggest that you take it back to the place inwhich you had the radiator removed... otherwise you should take it to an auto electrician who can chase down the electrical fault that seems to be linked to the thermofans.
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2009, 03:42 PM   #3
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
... and please turn off the caps lock :Reverend:
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2009, 04:10 PM   #4
The Monty
Just slidin'
The Monty's Avatar
Plug them back in and Im sure they will work. I know it sounds stupid, but mine werent clipped on when I bought it and had overheating probs.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2009, 04:11 PM   #5
The Monty
Just slidin'
The Monty's Avatar
Oh, the plug is near the battery, just a small loom.
