Old 05-06-2009, 03:54 PM   #1
The Monty
Just slidin'
The Monty's Avatar
Default AU 6 fuel systems
Ok, very soon Ill be upgrading my fuel system, as it cant cope with even the small amount of power Im making now.
Ill be Supercharging the car hopefully next year, so please keep this in mind.
What are peoples choice when it comes to Fuel regulator and fuel pump?
Are you able to use xr6t pump and reg, or is there an alternative?
What about on 044 and any good brand adjustable fuel reg?
How would you mount the pump, where, and would/are you using a surge tank?
Are the factory lines large enough to support, say, 240rwkw comfortably?
Any help would be great, and bullpoop in the thread and Ill ask for it to be closed,
Thanks,
Josh
MD Mondeo - For the family
NP Pajero - For the adventure
Old 05-06-2009, 06:16 PM   #2
ebxr82nv
The 044 are a great item, don't hear any complaints about them. Are you going to use it as well as the factory pump or instead? Surge tank only becomes needed above 350rwkw unless your planning on some circuit work. Wouldn't worry about the lines but there's plenty of people making more than 240 in forced setups with factory lines I'm sure.
I don't understand why your car is running out of fuel but, mine makes a smidgin more power than yours and doesn't run lean. Are you still running the 270kpa fuel reg?
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2009, 06:30 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Im running standard Au reg. Not the xr6 one. My fuel pump is so noisy before i start the car now, and I think its on it way out. Im basically only making power to 4900rpm, after that the tune was backed off as it just runs out of fuel, you put your foot down when theres less tha half a tank and it goes then just dies, foot down around a corner, same thing, just dies, then when your straight, picks up and goes again.
The cam and head Im using should and will spin to 6500rpm. So there is a lot more tuning still to do on it. So with my pump on the way out, and plans to s/c, I may as well do the whole lot now at once and have it done and ready to go.
Id rather use the 044 instead of my factory one as its about to die anyway, so I may as well just do it now and its done.
Old 05-06-2009, 06:32 PM   #4
The Monty
Just slidin'
The Monty's Avatar
Also as a quick note, Stav had his injectors max out at 160 odd kw. And mine is auto with a pretty big stall converter, which if I didnt have Id be around the 160 mark.
Old 05-06-2009, 06:32 PM   #5
Cam
Stroking it...
Cam's Avatar
As we'd discussed today I'd recommend an intank 044, although I run a Inline 044.
I have heard reasonably good things about Sard Performance Fuel Performance fuel pressure regs, so I'd recommend them.
Will allow you lots of scope for future mods including boost ;)
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2009, 06:37 PM   #6
The Monty
Just slidin'
The Monty's Avatar
What sort of connectors and brackets and joinery would I need to make it all fit? Or is it all pretty generic?
Old 05-06-2009, 07:08 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Obligatory 'LPG it' post
Old 06-06-2009, 06:18 AM   #8
The Monty
Just slidin'
The Monty's Avatar
Yeah I could LPG it, loose power and have it chew heaps of gas, and have restrictors all through it. But I might just past, as I dont want the extra 100 or whatever KG's in the boot and few kilos in the engine.
It has crossed my mind though, but its not what Im after for this car, thanks anyway.
