i have an EBII faimont and i was wondering why my cruise ctrl doesnt work? as usual you need to be going at least 50 kms for the cruise ctrl to activate, but my makes a funny noise behind the cluster, some kind of relay or something , do any of you guys have any suggestions for what to do to get it working again?
thanks |
Low and Loud
might be the Cruise ECU? but I think on EB2 they were mounted in the centre console so ignore that :P
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
oh is it that speed ctrl unit underneath the console? would i have to replace it.?
Low and Loud
that could be it, it also could be the actual mechanism in the enginebay...
#5 | |||
Bad Music and Litre Bikes
i was told by a former mechanic at work to check your brake lights. If they're not working then your cruise control wont... *shrugs* worth a try i suppose.
XY Wagon - NAKED! Quote:
i've checked everything now the only source is that speed control unit. im gonna change that and see how it goes, if its not that then i'm clueless. why all these problems just this mornin my fuel pump is playin up on me luckily i drove out of the driveway and died on me =\
Fuse or see that under the bonnet the cruise control cable is mounted correctly and hasnt come loose. It happened to me to (right beside the accelorator cable). The bolt mounting the cable came loose.
