Kurucu Performance
Hi guys...just wondeirng if anyone here knows how to reset the abs box so the warning light on an el xr6 manual switches off and how to reset the air bag warninglight aswell on the el xr6...we recently changed the rotors on the car...the rotors are abs ones.... the airbag had to be removed to pull off the dash so therefore the airbag warning light has also come up....anyone who can help fix this up...please post....
174rwkW N/A I6 Kurucu Performance Enhanced... Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph Now With EL XR6 Engine & ECU & 3.7 Gears Www.KurucuPerformance.Vze.Com |
as far as im aware, the only person who can reset this is Ford. Or there are mobile businesses such as Code Clear who come out and clear it for you for around $100, which im pretty sure is more expensive than ford, but i could be wrong.
hope that helps |
Any decent workshop should be equipped with a scan tool and should be able to clear it for you for a lot less than $100, but if it comes back and you want them to diagnose the problem, it could easily go over $100
Oops, I slipped....
There must be a problem with the ABS still, the light shouldn't come up just because you have changed your rotors, and the ABS light usually clears itself once the fault is fixed.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
not here much anymore
Airbag had to be removed to take off the dash? I'm assuming you mean passenger one, if so can I ask why the dash was removed? Last time i checked you dont need to take it out to put new rotors on.
RAM 1500
if you turned the key on while the airbag was disconnected, that could cause a code to be stored in the computer, but even a low battery voltage can come up as a trouble code which shows from the airbag light, still need a scan tool to clear them even if the problem has been rectified
Oops, I slipped....
Also, have a look at these 2 documents, they should help find out if there are faults with them.
http://www.fordmods.com/forums/documents.php?doc=2 http://www.fordmods.com/forums/documents.php?doc=3
I'll second what Aaron said, there must still be a fault with the ABS. Once faults are rectified the Check ABS light resets itself.
The Airbag light will need to be reset by Ford or someone with a scanner. Darin.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
Last warning
you can reset the airbag light yourself.
all uyou need to do is ground one of the pins on the diagnostic plug!
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
