Old 13-03-2009, 10:25 PM   #1
Muuna
Angry XR5T bottom end bearings
Hi guys I am new to this forum, I have a 07 LS XR5 Turbo and it has done 45,000 kms. I have had the car from almost new, had done 7000kms when I bought it.
The bottom end bearings have gone and Ford are having trouble fixing the problem...it's been six weeks so far...still have two more weeks to wait for three conrods to arrive. Ford cannot repair the engine it has had to go to an engine specialist to be assessed and fixed....under warranty tho.
The problem started with a ticking noise in the engine and they thought it was the lifters or the gudgeon pin at first.
Just wondering if anyone has had this problem before as I am running out of patience waiting for the car.
Muuna is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2009, 12:03 AM   #2
RS027
Perth XR5'er
RS027's Avatar
Man that truly is disappointing news. However given the reliable record in both the XR5 and all Volvo applications, the engine has proven to be very reliable. As far as the engine itself is concerned at moderate engine speeds the mechanical loading of the crankshaft drive remains modest despite high operating pressures (being a boosted engine). The XR5 engine has a maximum rating for the pistons’ speed of travel of 18.1 meters per second at 5500 rpm. Many experts regard 25 metres per second as the critical speed.
The power development of the five cylinder engine also ensures smooth running by its very design. Whilst four cylinder engines can face noticeable second order inertial forces, a crankshaft with five pistons as well as five forged and balanced rods is not affected by them. The second-order inertial forces have been successfully cancelled out by two counterweights on each of the crankshaft’s pins.
The engine’s alloy cylinder block is fixed to the ladder-shaped, cast aluminium bed-plate. This helps provide the six crankshaft bearings with solid support, which is of fundamental importance because of the high operating bearing loads of such turbo-charged engines.
Given all this and it’s record in other cars (this is not a new engine), I’d say you have just suffered a case of bad luck. I hope it’s all sorted for you very soon as they are a great car.
Ford Rallye Sport Club of WA; Member#64:
Barbagallo Short: 1:01.1779
Barbagallo Long: 1:12.4649
Collie: 55.90
K&N Gen2 57i CAI / 2XS RIP / Airtec Gen3 IC / Mongoose Dump Pipe / Outlaw 200cpsi Cat / Milltek Ultimate Race Catback / Whiteline 24mm RARB / Whiteline FALK / BC Racing BR-Spec Coilovers / RSR Rear Camber Arms / Ferodo DS2500 Pads F&R / Goodridge Braided Brake Lines / Elevate Torque Mount / DS MOD C / MkII RS Clutch & DMF / Quaife LSD
RS027 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2009, 12:03 PM   #3
Bucknaked
Bucknaked's Avatar
I've heard of 2 engines needing replacement. You should come over the www.fordxr5turbo.com and post the topic there. You may get some answers your looking for.
Not good news at all. Sorry to hear of your hassle.s What colour is the car. Blue is my bet :hihi:
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Old 14-03-2009, 10:25 PM   #4
Muuna
Thanks for the tip I will try that. Interesting that you said that you know of two engines needing replacing as Ford told me that mine was the first that they have had any problems with....oh well another lie...must be because I am female. The car is silver too. Cheers
