Old 07-03-2009, 06:54 PM   #1
BFD83
BFD83's Avatar
Exclamation Weird ticking sound coming from engine
Please can someone help me! There is this weird ticking type noise coming from the engine, originally when i start it up in the morning for the first few seconds it would make a ticking noise but then go away...now ive noticed it's getting more louder and more constant. When i accelerate the ticking gets louder but when i take my foot off the sound fades but you can still hear it just not as bad...my mechanic thought it was the pulleys rattling that was cauzing the problem with i originally told him about it, got them replaced this morning...140bucks later and it wasnt even the problem! Does anyone have any idea of what this noise would be?
Cheers!
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2009, 07:41 PM   #2
Eu-GenixX
Eu-GenixX's Avatar
lifters? tappets? whatever they are called.. :$... heh
check oil levels?
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2009, 08:04 PM   #3
BFD83
BFD83's Avatar
It's had a service like 4,000k's ago and its due for a major one in another 1,000. im taking it down to mechanics first thing monday and make sure they find the problem.
Old 07-03-2009, 08:33 PM   #4
atec77
Cheers!
Hdrolic valve lash adjusters , oil change usually helps (and filter) but find another brand until you have one that works , my ef tics for 5 seconds and then goes..
Old 08-03-2009, 12:47 PM   #5
SSD-85
I've got the same issue, goes away when it's warm. I was told change the oil used in it. So ill find out in about 2000k's
It would appear you have an XR6, i thought OHC doesn't have lifters...
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 01:43 PM   #6
adrian k
adrian
adrian k's Avatar
yep they do have the hydraulic lifters, and they will tick until they are filled with oil. if the oil is too think, it wont go into the little holes that allow it to fill up.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 01:55 PM   #7
honer
Back to N/A land
Could also be exhaust manifold gaskets
honer is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 02:38 PM   #8
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Theres a thought.
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 02:56 PM   #9
XRSIKS
XRSIKS's Avatar
My brother had this issue with his Tickford AUIII 8.... he started using Premium unleaded and the issue went away.
Previous -
Mazda 2 Genki
BF XR6 - Seduce
BF MK II XR8 - ToXiC...
Toyota Camry Altise
After a patient 2 years...
Now Driving...
2010 FG XR6 - Sunburst!
XRSIKS is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2009, 05:57 PM   #10
sikford
THE Fairmont Ghia 75th
sikford's Avatar
it will be the liters as mine is doing the same thing atm, if the head is coming off ill change everything i possibly can just so i know its been done.lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
