Old 06-03-2009, 06:59 PM   #1
Loris
Focus & Territory TDCi
Default Power windows problem
I think i might have a problem with my drivers side windows.
when i push for the window to go down it does so automically but when i go to put it back up i have to hold it up, for the window to go back up.. i dont need to this for any of the other windows.. it was working fine last week.. its all of a sudden not going back up on its own automatically.
when i hold the unlock button on my remote for a couple of seconds all the windows go down, when i hold the lock button all the windows go back up except the drivers window..
is this a function or something ive accidently enabled\disabled or is the power window switch or something stuffed?
Thanks in advance
Loris.
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2009, 07:58 PM   #2
RJO89
EuroFordClub
RJO89's Avatar
Sounds like the double click trigger button that is the driver side window switch isn't pushing down far enough to engage the auto-up. Can't explain why it doesn't go up when you hold the lock button. Maybe a relay? Will be a warranty issue either way.
'08 Black Ford Focus LT CL Hatch
Far from stock... --- SOLD :
Now riding a 2009 Kawasaki Ninja 250R :
RJO89 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2009, 08:40 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
I didn't think you could have auto up for safety reasons.(eg kid getting head or hand caught)
The LR is auto down but not auto up
Old 06-03-2009, 09:48 PM   #4
Loris
yer thats how it is in my mates car.. but my car has been going auto up since day one.. i dont mind really if it doesnt go auto up from inside but i want it to go up with all the other windows when i hold the lock button down on my remote
Old 06-03-2009, 11:48 PM   #5
Lanyi
Lanyi's Avatar
I've had this occur every time I disconnected the car's battery. What I have done, and suggest doing, is that you hold down (or up) the driver side window switch for a good 5 seconds or longer after the window has opened or closed. The auto-up/down function has to be manually re-set.
Hope that works, otherwise rjo might be right, the switch isn't working anymore.
Lanyi is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2009, 12:29 AM   #6
DZFord
DZFord's Avatar
^ what he says! Same experiences on my car.
Old 07-03-2009, 11:00 AM   #7
Loris
Thanks heaps it worked!!
Thing is though i never disconnected the battery.. only thing i can think of is when I plugged in (and now removed) the tuning chip from my car. It started happening around that time.. so I blame it on that
thanks again!
Old 07-03-2009, 12:39 PM   #8
BlackLS
yum
Probably that. Also if you used auto up twice in a row and the safety lock off was activated, it will make you wind up the window by holding it all the time.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire
250,000kms.
BlackLS is offline   Reply With Quote Multi-Quote with this Post
