4dlvr
i want to change the head unit on the focus, i understand its a 1.5 din so my question is, is there any head units which are 1.5 din and fit straight in???
i cant be bothered with a single din and a spacer.. has any one done this??? also im assuming the swap over will be like every over would be like every other car??? eg pull out old one, wire new one, push in???
96 EF FAIRMONT Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust. 215rwkw @7psi |
yum
No the mounting on the standard unit will be different to aftermarket units.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
4dlvr
what do you mean mounting will be different???
i understand the sides are different and it may not slip in perfectly, but the aftermarket deck should have brackets to compensate..
I have not found a 1.5 DIN unit for the LR so I just kept the single DIN. I got a spacer from my Focus if you want to go that way in the end.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
