Old 22-07-2005, 03:49 PM   #1
Syk0AU1
Default jumpy idle
I just recently reset everything, took off the power from the battery and then reconnected after an hour or so. It drove good for half an hour or so until the idle began to get all jumpy, and it has been ever since yesterday when i did it. how can i fix this problem?
AU S1 Forte - White
Syk0AU1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2005, 03:55 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
There is a procedure to set the idle after connection of battery, cant recall it exactley but basically after you start it
Put it in reverse then drive then turn the a/c on, then put it in park, then turn the wheels full lock to lock, then turn the a/c off. Go for a drive and make sure you give a full boot fulls so it learns what WOT is, should then idle fine.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2005, 05:32 PM   #3
Syk0AU1
ok ill give that a try and see what happens, thanks
AU S1 Forte - White
