Old 20-11-2008, 07:27 PM   #1
snappy
snappy's Avatar
Default After Panel Beater (Vic)
Im After a Panel beater that does not mind a bit of a challenge.(or plenty of time)
I have a fair bit of custom work i would like done to my ute. pretty much turning this
in to this (roughly done but you get the idea)
snappy is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2008, 10:28 PM   #2
mad cow
blue oval addict
give lincoln at lwm panels in echuca a call, he does custom jobs from all over vic and nsw and is an absolte perfectionist. his prices are not over the top either. if you dont mind travelling to get a good job he is your man. his ph no is 0354825300 or 0418579087 he has done work for me so i can personally reccomend his work, and he only operates from referals (always busy) well worth the travel. if youdo call him tell him the guy wih the kashmir territory sent you. cheers.. james...
mad cow is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2008, 11:38 PM   #3
snappy
snappy's Avatar
Thanks .
I change my idea a little instead of splice two tubs together to make up the length of the tray . I just gonna shorten the tray to sit on the cut tub .
I tell you i wish i never sold my tub .
Also i would not need to anything if the fella that made the tray did a desent job.
Have a look at the wheel arches on the top photo way out of centre and the whole powder coat is peeling and really rusty.
Its only 18 months old tops to. Quality work is hard to find
Old 21-11-2008, 08:46 AM   #4
Jason[98.EL]
Jason[98.EL]'s Avatar
snappy Blakes body repairs is a good place to look at
does great work he is about the only person i trust with body work on my el
he is on Thompson road nth geelong ph 52770097
hope that helps
Grimus
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2008, 10:58 PM   #5
mad cow
blue oval addict
yeah its somthing that most tray builders seem to suffer from, they simply dont do any prep work before sending to the painters/powdercoaters, they also seem to suck at color matching.
