Old 22-11-2008, 04:26 PM   #1
brad`
The Monty
brad`'s Avatar
Default tickford badge hight from indicator
i was woundering how high the tickford wings sit from the side indicators roughly ?
hope someone can get back to me a.s.a.p while the rain holds off,
cheers
brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2008, 04:42 PM   #2
mattp
mattp's Avatar
Just eyeball a few photos, then get some masking tape and run a line along where you want the top of the badge to sit, then you can make sure it's level before you stick it on. It doesn't have to be a specific height, as long as it's the same on both sides. I'll measure mine and get back to you if that helps, but I just stuck them where I thought they looked 'right'. This photo will give you an idea though:
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2008, 05:24 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
They're ment to sit where mattp's are, so that an XR6/XR8 badge can fit inbetween it and the indicator.
I quite like where mine are though. Seeing as no XR badge will ever go there.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
