Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Perth Falcons
Old 08-11-2008, 04:59 PM   #1
geraldbb
Ex Ford Engineer
geraldbb's Avatar
Default Recommend a Transmission Workshop?
Hi there,
I just bought a AUIII XR8 Pursuit Ute. 64,000km's. Stunning vehicle! I used to work for Ford when these were coming off the assembly line, and always wanted one.
My only issue is gearbox related. It is a manual Tremec T5. This vehicle has had ongoing transmission issues since new, starting with excessive rollover noise (gear noise when clutch not engaged), and had work done under warranty as follows;
Input Bearing Replaced.
New clutch
Exchange Transmission
Clutch Thrust Bearing replaced
New Transmission/Clutch
The new Transmission is a BA Tremec T5, and required a custom tailshaft.
It still has excessive rollover noise (I can live with it), but has a low pitched mechanical droning noise, intermittently, when 1st or reverse is selected. There is no vibration associated with the noise. No performance issues, except the odd rough shift, any gear.
McInerney Ford advised the Tranmission conversion isn't the best they've seen and pointed out the modification required to the cross member to fit the different gearbox could be better.
Does anyone know a workshop that has experience with T5's, and could help me out with repairs if required or advice?
I work FIFO in Newman, and only home 6 days a month. Obviously I want to spend that time driving the car not shopping around for a good shop, or getting buggered around by a bad one......
Also, anyone with an XR6/8 RH Headlight assembly for sale, please contact me
Best regards,
Gerald.
geraldbb is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2008, 05:05 PM   #2
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
can't fault Top Quality Transmissions
Holden: If you cant beat them, buy them.
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2008, 06:22 PM   #3
Biggav
On the search for cubes..
Biggav's Avatar
one of our sponsors TLT automotive uses/recommends the guys at Auto Trans R Us in Os Park.
9242 7221
give em a ring even though your after a manual they might be able to help
FG G6ET - Daily Driveway Ornament...
Current Projects
ED SOHC 3v 5.4 Cammed 5.4 3V Garage Ornament Project
Project Brimstone XE Wagon Phase 6 powered by Coyote
Long Gone Projects
EA Falcon SOHC 4.0 237rwhp
BA 3V 'The Taxi' DJR320 Kit, G6ET Wheels, Lunati Voodoo Cams 320rwhp
Biggav is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2008, 11:54 AM   #4
66 coupe
around the place
66 coupe's Avatar
its a manual - so auto shops wont be able to help
give aldo a call at ad diffs
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
