Old 27-07-2008, 01:28 PM   #1
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Default XE Rear Drag Suspension
I'm thinking about buying an XE and throwing my 9" rear in it (weld on few brackets and spring mounts). Just wondering if anyone has had much experience with the 4 trailing arm type suspension.
I see you can get aftermarket adjustable uppers (for pinion angle adjustment). How does this effect the upper and lower spring mount geometry?
Mainly for drag racing. Not quite the full 4 link, but it would be nice to fit some adjustable front mounting points for the lower arms to play with IC's etc.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2008, 10:25 PM   #2
GASXR6
GASXR6's Avatar
friends of mine have a couple here in Perth and the more street orientated one still runs factory trailing arms with nolethane bushes, also has a torque arm I think. She has run a 10.30 from memory.
383 Clevo, CHI 3V's, solid roller, Glide. 7.97@164.83 mph.
GASXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2008, 10:30 PM   #3
ebxr8240
Performance moderator
ebxr8240's Avatar
Could you not weld in upper torque box to accept same length as lower ??
If its mainly drag?? Depends on rules and class your running in..
Daily driver GTE FG..
Old 28-07-2008, 01:48 AM   #4
TruBlu351
TruBlu351's Avatar
Thanks guys..........well, if a chick can pull a 10.3, I'd be happy with a 10.9 lol ;)
I'd run in S/ST, but with an 11.0 lower limit (and 98dB ) , I would like to run consistent 10's so it looks like SS/A when setup right.
Just reading the rules..........looks like 4 link type setups are good to go with no real restrictions on the rear setup.
I'll see if I can get a look under one and see what may need cutting out under the floor.
Old 28-07-2008, 11:15 AM   #5
FDG 220
Confused lil guy
FDG 220's Avatar
Beauty about SS/A is you get to dial your own index so not neccassarily the quickest car wins
I've just bought an XF that will be running in this class also so guess i'll see ya on the track
FDG 220 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2008, 06:17 PM   #6
xdclevo
The Fun Mobile
xdclevo's Avatar
He'll be ok when he learns to swap cogs with the 5 speed
Is that a Metalic green XE?
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2008, 10:00 PM   #7
debacle-racing
debacle-racing's Avatar
adrian, contact paul (xf1101) he runs an 2v xf sedan that runs 10.60 and it leaves awesome, just pm him and he might be able to point you in the right direction.
why dont you just stick to your caltracs?
Originally Posted by TruBlu351
..........and thanks to Justin from Debacle Racing for helping me hook up and break parts
debacle-racing is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2008, 10:47 PM   #8
GASXR6
GASXR6's Avatar
Yep thats the one, She races that at the Fast Fridays and her other race car at National meets. I think She's run a 10.20 in the silver car. AFD headed 393 in the silver car and CHI headed in the green car. New big block coming for the green car and the CHI headed going into a 3/4 chassis corty for hubby to play with. Hope everyone has a seat when the music stops.
The torque arm setup is available from WA Suspensions.
Old 29-07-2008, 08:04 AM   #9
TruBlu351
TruBlu351's Avatar
I got 3 out of 5 gears on my 2nd last run, and only 1st gear on my last run So we have a good learning trend there ;)
I didn't think about running the rear leafs and current setup which would be nice. I could always go XD with XE panels........
I guess I could simply weld on the front and rear leaf spring mounts and she'll be good to go......and the upper shock mounts. I'm sure that wouldn't be too hard.
Old 29-07-2008, 09:06 AM   #10
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Ive been thinking about them mono leafs Adrian,seen some circuit guys running them even,seem to be the hot ticket...
Certainly seems an easier option with the amount of people running them..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2008, 01:25 PM   #11
pdh8953
BOSS 418
pdh8953's Avatar
MY XE HAS STANDARD REAR SUSPENSION AND RAN 11.3 @ 124MPH WITH A BORG WARNER DIFF. I'M CONVERTING IT TO 9 INCH AT THE MOMENT IT'S ALMOST FININSHED. IT HAS 401 RWHP AND WITH THE NEW REAR END I'M HOPING TO RUN HI 10'S. I THINK THE REAR END WILL HOLD UP FINE, ALL I DID WHEN I GOT THE CAR WAS PUT NEW BUSHES IN THE TRAILING ARMS AND NEW SHOCKS, SO FAR SO GOOD!
pdh8953 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 11:18 PM   #12
xwgasaxe
under new management
xwgasaxe's Avatar
Adrian,
I feel your plight with the old cart springs in the rear.
It crossed my mind the other day about modifying the rear end to accept an XE trailing arm rear end.
If you give it a crack then I just might too........
XW tarmac rally car, 3/4 race cam, NGK spark plugs
xwgasaxe is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2008, 02:40 AM   #13
TruBlu351
TruBlu351's Avatar
Hah!
Mate, I'm spying on the best XE Grandpa car I've ever seen.........on ebay.....waiting for the 5 sec to go sniper shot bid!!!
Old 22-08-2008, 03:15 PM   #14
xwgasaxe
xwgasaxe's Avatar
Betcha 10 bucks that you build a Greens tuff replica!!!!
Old 25-08-2008, 08:54 AM   #15
FRDPWR
416w 10.5@127mph
FRDPWR's Avatar
ive got a 9" in the rear of my xe, all i have done is bought new upper and lower arms, i think i bought them from repco. i purchased the boxed tubes. they seem to work fine
car has gone 10.50@128mph
the Fleet - 360rwk XE ESP - 314rwk G6ET - 245rwk XR GT - 205rwk '67 Stingray
FRDPWR is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2008, 09:47 AM   #16
TruBlu351
TruBlu351's Avatar
Thanks mate. Yeah, someone I called the other day mentioned the boxed tubes for more strength. Cheers
