Old 28-06-2008, 03:09 PM   #1
BIGJB
BIGJB's Avatar
Question Steering wheel fitting problem
I just brought a new momo steering wheel for the au. Upon inspection some tool has already had the wheel of the car or at least tried!!!! The threads you put the pully bolts into are totally screwed. Has any one got any idea how I can get the existing wheel off without a pulley?? Why do people insist on doing things with incorrect tooling or the knowledge of how to use them. GRRRRR!!!!! :
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2008, 03:38 PM   #2
chief
FTF Club Moderator
chief's Avatar
Be careful if you start whacking the steering wheel to get it off. Just under the dash the steering column is supported by two bolts that attached via plastic clips. So when in an impact they brake and the column collapses. Found out the hard way.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2008, 03:42 PM   #3
howesy
howesy's Avatar
Never used a tool in my life. With the nut on still a few threads (so you dont slam yourself in the face) Seat back feet firmly up against the fire wall you straighten your legs and with all your might using arms back and legs you pull on the wheel changing pressure from side to side. As you do this the whole column will move and flex that muck you will think holy F@*k It's going to break and then it will let go with a vengence which is when you will thank me for the tip about the nut because without doing that hospital for stitches is a real possibility.
P.S. When I took mine off I noticed that ford had something like loctite on it. prob. flowed in from using on the steering wheel nut
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2008, 04:14 PM   #4
BIGJB
BIGJB's Avatar
I got the darn thing off..... Loctite you say.... anyone would think it was welded on if they just went through wat I did. lmao. But its done and how darn SEXYit looks too.
Thanks man you a ledgend. Oh and no steering wheel colapse lol
Old 28-06-2008, 06:14 PM   #5
GK
Walking with God
GK's Avatar
This thread is useless without pics!
Glad you got it sorted though.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 28-06-2008, 06:43 PM   #6
BIGJB
BIGJB's Avatar
There stop complaining...lol
Old 28-06-2008, 07:43 PM   #7
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
Looks good.
I have a puller set that you could have used for that.
Sorry I didn't read this earlier.
When I grow up, I want to be half as good as you THINK you are.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
