Old 26-06-2008, 03:31 AM   #1
Bolly
Bolly's Avatar
Default Water in AU2 XR8 Headlight 2000 model
I noticed my left headlight had condensation, further examination i found that my head light was quater full with water.. The car has only done 35,000 Kilo`s......Just wondering how does the water get into a sealed beam headlight? And how do you remove it? It seems the nose has to be removed, Hope there`s a easier way..
Kevin :
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2008, 08:18 AM   #2
RG
Back to Le Frenchy
RG's Avatar
Kevin :
Because it isn't a sealed beam light. Bad glue or a crack somewhere will do it.
Old 26-06-2008, 09:19 AM   #3
Peuty
Afterburner + skids =
Peuty's Avatar
As far as removing the nosecone, it's not very hard. It's just six bolts, but you will need the hands of a midget in some places.
Oo\===/oO
Old 26-06-2008, 09:20 AM   #4
RG
Back to Le Frenchy
RG's Avatar
and always remember where things were so you can put them back on correctly, isn't that right Peuty
Old 26-06-2008, 09:24 AM   #5
Peuty
Peuty's Avatar
Yes, well, erm, uh........
Thats correct Russell, thanks for pointing that out!
Oo\===/oO
Old 26-06-2008, 11:04 AM   #6
FTE217
T3/Sprint8
FTE217's Avatar
Bolly, just had mine repaired from The Headlight Hospital run and owned by a fellow forum member here known as DOK.
Scott is Melb based and he reseals them and replaces reflecteors if required.
Great service and a great price and I'm based in Sydney.
Mine being a TSeries black bezel Ford want $480+gst coughcough !
I have his mobile if you require.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
FTE217 is online now   Reply With Quote Multi-Quote with this Post
Old 26-06-2008, 01:36 PM   #7
howesy
howesy's Avatar
Hey mate have you got the rubber caps on the back of the light? I took mine off and thought it would make it easier to replace a globe if need be and it seems that without them water seems to run into the light. put em back on and no leaks. Without them mine too filled a third full of water after days of consistant heavy rain, To empty them I pulled the globe out and inserted some plastic tube (u can use vacuum hose) into the bottom of the light and sucked it up in lots until it was empty, took a couple a minutes each light and no need to dismantle anything.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2008, 06:42 PM   #8
Bolly
Bolly's Avatar
Default Headlight
Thanks Howesy
As soon as i read your message, i didn`t remember seeing a rubber seal at the back of the left headlight. So i had a quick look and its missing, but the right headlight seal is still fitted.. THANKS for your advice Howesy..
Can you still buy them at the Ford Dealership??
Old 26-06-2008, 07:07 PM   #9
howesy
howesy's Avatar
Thanks Howesy
Not sure mate but mine hasn't leaked a drop since.
ECU
Exhaust
Adjust. Rollers
Cold air
