Old 12-06-2005, 08:33 PM   #1
xr8 007
xr8 007's Avatar
Default Xr Globe Change!!
Hey all.
i had a good read of my owners manual and i have the max ellery's repair manual, but i still cant change my driving lights. I'm not sure of how 2 take the main terminal off??
So guys/girls how is it done on the XR's and the brake lights and reverse lights need changing how do i get 2 them?
thanks a bunch!!
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2005, 07:07 PM   #2
xr8 007
xr8 007's Avatar
Anyone??
Old 13-06-2005, 07:17 PM   #3
12
Silhouette AU1 TS50.
12's Avatar
On the plug there should be two retaining clips on two sides. Press both and pull out the wiring harness plug. Remove the dust cover and the springed globe retaining clip. Pull out the globe. That should be it for the headlights.
For the taillights, in the boot, remove the carpet behind the light you wish to replace the globe for. Remove the two screws from the outside and the 10mm nut from the inside of the car. Pull out the taillight. From there it's pretty obvious. Hope it helps.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2005, 08:57 PM   #4
xr8 007
xr8 007's Avatar
Thanks a bunch dude!! So on the head lights u must "PRESS IN" both sides to release them from the globe??
Old 14-06-2005, 01:14 PM   #5
xr8 007
xr8 007's Avatar
somethings wrong cause i pressed till i almost broke my fingers in frustration and i still get them out..
Old 14-06-2005, 02:14 PM   #6
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
With the rubber surround (Well, this is how it is with my ute), stick your fingers right up in it and squeeze. The plug should come out. And be careful with the little metal clip, cause that's a pain trying to get back in properly.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2005, 12:40 AM   #7
Mechan1k
Mechan1k's Avatar
Yeah I had issues with it as well ... a mate of mine (used to be a Ford Mechanic) did it in seconds ... must be a knack to it ... he has replaced heaps .. LOL
A bit off topic ... I got a dual filament globe for the passenger side taillight in the ute ... took the light out and got the globe out ... would you believe it's a damn wedge dual filament globe (first time I ahve seen one of these ever ... LOL).
Now I have to get the wedge type globes ... damn ... I got the bayonet cap dual filaments ... oh well ... they can be used on one of the other cars if they needs replacing ... LOL
Old 02-07-2005, 04:43 PM   #8
DJM83
Barra Turbo > V8
DJM83's Avatar
yeah im havin trouble changing mine aswell it says u have to dissconnect the parker aswell to change the low beam so i have 1 dull and 1 bright light
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 02-07-2005, 04:58 PM   #9
12
12's Avatar
Huh!!
Sorry.. like to help you, but I can't read that language. Sorry 00VenomXR, but I've tried to read all your posts but.. ahh! . You've done well with your signature, try keep it up on your posts too.
PIC'S OF MY
T1 TS50.
Old 02-07-2005, 07:10 PM   #10
DJM83
Barra Turbo > V8
DJM83's Avatar
Originally Posted by AUGZMK
Huh!!
lol Sorry mate i think it me sednig to many text messages.
Yeah ive been trying to change my low beams in my car but the manual says u have to remove the parker in order to change it, because its a pain in the *** driving with 1 dull light. ( Look at that full stops and all) :Reverend: any help muchly appreciated
Old 02-07-2005, 07:22 PM   #11
Casper
Contributing Member
Casper's Avatar
Parker does not have to be removed to change the low beam. Just replace the main globe and your good to go.
The XR's are shocking when one light goes. Cause they are recessed so far back you only get light on one side, the other side is black!
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
