Old 23-06-2008, 07:21 AM   #1
Gambit
Gambit's Avatar
Default wheel bearings
What is the correct torque to do the nut up to on the front au wheel bearings?
Gambit is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2008, 09:39 AM   #2
Mont5.0
Mont5.0's Avatar
http://www.fordforums.com.au/vbporta...article&id=158
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2008, 10:19 AM   #3
Gambit
Gambit's Avatar
thanks mate. it says on the torque it to 255-354nm. What is the right setting?
Old 23-06-2008, 10:26 AM   #4
Mont5.0
Mont5.0's Avatar
found better info: 13.Install new hub by sliding onto shaft. Apply Loctite or similar to thread and tighten hub nut with tension wrench to 305Nm (225 lbs ft)
