Old 28-05-2008, 09:20 AM   #1
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Default Odomoter Globes
After my saga with the coloured LED's in my dash, my Odo globes have gone now, which I need to replace.
Pulled one out, they don't look like standard T5 like the rest, would appreciate it if somebody could tell me what kind of globe (code) they are so I can head down to a store and grab a couple more.
Thanks heaps.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 10:57 AM   #2
BHDOGS
Hey riksta there not the normal t5s with the removable bulbs there a globe and holder in one and hard to seperate. Not sure on the code just take one out and go down to u pull it and grab out as many spares as you can the ef/el has the same globes in there demister switch and in the back of there dash if you cant find any au ones.
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 04:12 PM   #3
Riksta
Riksta's Avatar
Cheers, I thought from the look they were all in one piece.
Will hit U Pull It on the weekend see if I can find any.
Old 28-05-2008, 04:15 PM   #4
5L
[ 5L ]
5L's Avatar
lol mfc u pull it run. should cruise to the northern u pull it, then the southern one.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2008, 05:33 PM   #5
Riksta
Riksta's Avatar
ROFL, that's not a bad idea hey! Should contact them see if we can get a group of us in with free entry :P
Old 28-05-2008, 11:03 PM   #6
BHDOGS
ill be in to cruise down to u pull it norlunga nothing wrong with having a poke around might grab a rear passenger handle if theres one there
Old 29-05-2008, 05:25 AM   #7
5L
[ 5L ]
5L's Avatar
id be up for it, i dont need anything for my car.
but for the $1 entry fee sometimes you walk out with something that you never intended too.
Old 29-05-2008, 08:33 PM   #8
Mechan1k
Mechan1k's Avatar
I bought mine from repco from memory ... can be purchased over the counter as one item.
Old 01-06-2008, 05:15 PM   #9
Riksta
Riksta's Avatar
Well, I went into Repco and managed to get a couple of the globes so that my odo display would be lit at night.
Got home, put them in, turned the car on to test them and they don't seem to be lighting at all. I'm hoping it was just the light outside that you couldn't see it, but unfortunately even with the towel trick it didn't seem lit at all.
Fast getting over the whole dash mods, I've got a couple of coloured LED's for the speedo now, I think I'll just leave things how they are until I get sick to death of the odo not being lit, then I'll take it somewhere and pay someone unless anyone's got any more suggestions?
Old 01-06-2008, 05:46 PM   #10
BHDOGS
try taking out the bulbs and turning them around in the other direction
Old 01-06-2008, 07:14 PM   #11
Riksta
Riksta's Avatar
Does that matter with normal globes, I thought that was only LED's that had to have the current the right way round?
Old 01-06-2008, 08:25 PM   #12
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Yes you are right Riksta, but my ODE display originally had globes in it, and when i got replacement items from ford they were LED's. So it couldn't hurt to check.
And by they way, i had the same problem as you. Put blue LED's in my dash and my ode globes blew straight away. Hmmm, interesting.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2008, 08:31 PM   #13
Riksta
Riksta's Avatar
These ones are definitely bulbs, you can see the filament and all in them.
However, the comment "i had the same problem as you. Put blue LED's in my dash and my ode globes blew straight away. Hmmm, interesting." that you made has got me thinking. Would the LED's use less power, diverting more to the Odo globes, causing them to blow in a hurry? I dunno, just a random thought.
Old 01-06-2008, 08:35 PM   #14
superroo
superroo's Avatar
More info for you, my ODE display is permanatly stuck on too. Which seeing how it only turned up once the LED's were in, and you had the same initial problem as what i had, helps me track that down.
Old 01-06-2008, 11:42 PM   #15
MeLLy
MeLLy's Avatar
if u decided to go back to normal lights riksta ill grab those blue leds of ya ;)
2008 BF F6 Typhoon, 19" dark argents
B**** with Boost
MeLLy is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2008, 12:14 AM   #16
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
A friend put these blue led in his AU dash and for some reason it fried the copper circuit!! cost him a new cluster.
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2008, 02:24 AM   #17
T-Pak Addict
Jim
T-Pak Addict's Avatar
can get from fords.... not cheap tho....
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 05:54 PM   #18
Riksta
Riksta's Avatar
Sorry to repeatedly drag this up, but the globes I got from Repco seem to be working!
After posting that they didn't work, giving up on them and just leaving them in there, I've noticed driving along that one of them seems to come off and on as it pleases. I'm going to clean the contacts on both the globe and the dash, and make sure they definitely are making contact, I think maybe it might be a simple fix after all. Fingers crossed!
