Old 22-03-2008, 07:05 PM   #1
last fairlane
last fairlane's Avatar
Question Fairmont electric antenna
Hi guys
does any one know how to remove and replace the electric aerial on a series one Fairmont sedan do you have to remove the mud guard or is there a way round it
thanks JOHN
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2008, 07:26 PM   #2
HLC
Audi S3
i *THINK* you remove the plastic splash guard thing around tyre and you can access it from under there.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2008, 07:45 PM   #3
FGII-XR6
FGII-XR6's Avatar
you remove the plastic inner gaurd and unplug it from the kick pannel just above the ECU
[SIGPIC][/SIGPIC]
Rides:
Old 22-03-2008, 11:12 PM   #4
last fairlane
Wink removing electric aerial
thanks guys for the info I will have a go at it
thanks again John
Old 24-03-2008, 08:40 PM   #5
Mechan1k
Mechan1k's Avatar
Can any power antenna be used (aftermarket ones specific for AUs) ... or does it need to be from Ford themselves????
Old 24-03-2008, 08:49 PM   #6
JMO
JMO's Avatar
I'm pretty sure an after market one will fit. Just take the old one to the store with you and compare the connector. Someone on here will definately know though.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 11:28 AM   #7
BillC
Best thing I ever did when it comes to auto antenna's is get rid of them. Auto antenna's are only good for a couple of years and they break. Replace it with a standard antenna (about $30 from supercheap and they last forever) compare this to about $180 for an aftermarket one that will only last 3 years max.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 11:59 AM   #8
NC1183
NC1183's Avatar
I replaced my standard antenna with an electric one, and on my first trip away with it, it got hit by a bird and bent it. I talked to my brother about it and he said you can by replacement shafts and they only cost $30.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 12:05 PM   #9
superroo
You can't stop the signal
superroo's Avatar
Yes aftermarket ones fit. I've had 2 in mine so far. A $30 one from kmart which fitted straight in, and now i have an $70ish one from supercheap, but it required some "massaging" of when the antenea sits, due to it being about twice the size of my first one.
Yes they fit, but they will require some playing around to make them fit properly.
Old 25-03-2008, 12:09 PM   #10
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
You know what we used to do with electric antenna's on the cabs? Unplug them!
We always just ran the aerials with the two thickest parts of the shaft up, the other little flimsy ones inside. Hardly ever had any troubles.
Old 25-03-2008, 02:17 PM   #11
FGII-XR6
FGII-XR6's Avatar
aerpro make 2 units one to replace a factory one and one for where there was not a factory fitted unit . the wiring and electronics are different
[SIGPIC][/SIGPIC]
Rides:
Old 25-03-2008, 08:31 PM   #12
Mechan1k
Mechan1k's Avatar
Cool ... good information here.
Mine just stays up all of the time ... has been for a while (even after I turn ACC off).
I just haven't bothered looking at mine ... it's either a dead aerial ... or a connection has come loose.
