19-12-2007, 11:23 PM | #61 | |||
aka SHY4D aka Patty
20-12-2007, 02:17 AM | #62 | ||
What Wheelspin?
where and how much for your 3500rpm stall patty? i was wanting to do the same this to mine. only have had one quote so far.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
20-12-2007, 05:22 PM | #63 | |||
Big Block All The Way
Yes it is turbo now, back then it was N/A with a Motec M800, T5, and 3.9 gears and went 13.2 Then it was on NOS 12.2 with the T5 with 250 ish rwkw Then went 11.8 with the same tune and a C10 and transbrake Now it has the turbo with 380rwkw and has gone 10.0 and yes I have seen this car on the dyno, so I have no reason doubt the power it is making and I think the time speek for them selves. |
20-12-2007, 08:28 PM | #64 | |||
aka SHY4D aka Patty
dominator with lock up....im going through ronnie at geelong engine replacement services and it'll be in by lunch time friday! |
28-01-2008, 10:28 AM | #65 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
28-01-2008, 03:31 PM | #66 | ||
hoons cause global warmin
au injectors are the same as eseries ones
19lb
"if you believe you can, or believe you cant, your probably right" (henry ford) |
28-01-2008, 04:09 PM | #67 | ||
EL Futura T5
my Futura has recently tipped 217HP (165kw) at the rear wheels
EL Futura: 4.0 L6, Factory 5spd Manual Project Twisty |
28-01-2008, 06:27 PM | #68 | |||
Smile
28-01-2008, 07:41 PM | #69 | ||
YEAH IT IS A FORD
POWERED BY CVE www.cveperformance.com EF PS1WGN - 2013 AFF PROJECT CAR OF YEAR http://fordforums.com.au/showthread.php?t=11390858 STILL THE QUICKEST AFTER 4 years NA6 e series EA BROCK 225rwkw - 12.85 |
29-01-2008, 12:54 AM | #70 | |||
au= 20lb or 205cc (41hp) ea-el= 18lb or 185cc (37hp)
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile # 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys |
29-01-2008, 01:11 AM | #71 | |||
What's green is gold
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
29-01-2008, 10:16 PM | #72 | ||
Smile
The ba injectors different spray pattern .Au and e series should be the same.
