View Poll Results: IS the Parts Database a useful tool ?
Yes 64 42.38%
No 15 9.93%
It needs work 29 19.21%
It needs more models 22 14.57%
What Parts Database? 54 35.76%
Multiple Choice Poll. Voters: 151. You may not vote on this poll
Old 15-05-2007, 07:22 PM   #31
Jason[98.EL]
Jason[98.EL]'s Avatar
personally i dont like it
i just done a search for head/cylinder head for el and got no results
jason
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2007, 07:36 PM   #32
russellw
Chairman & Administrator
russellw's Avatar
That's probably because they are an obsolete part now - hardly an issue with the database itself.
AU 6009 A CYL HEAD ASSY $2055.00
They still exist for the AU.
Russ
Observatio Facta Rotae
Old 16-05-2007, 07:53 AM   #33
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
I'm a BA XR8/SX Ghia owner, and would DEFINITELY refer to it if these models were included.
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 08:16 AM   #34
ltd
Force Fed Fords
ltd's Avatar
Didn't know it existed, but am doing a full reco on the AU2 LTD, so am now really happy about this useful resource tool.
Good job guys.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 11:37 AM   #35
russellw
russellw's Avatar
Lukeyson
They are - the BA and SX Territory were added some time ago. They appear on the top drop down as BA and SX respectively.
Russ
Old 16-05-2007, 12:49 PM   #36
Sapper
Back to the AU
Sapper's Avatar
Is there any way that results can be posted on more than on page. For instance, I was looking for details on the BA/BF VCT module and the only search terms that produced any results produced so many results that it wouldn't display the results I was after. Apart from this, the database is pretty good.
Oh, and thanks Russ for the help with the login problem.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU
2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth
Sapper is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 12:50 PM   #37
aussiedv8
aussiedv8's Avatar
Good job Russ, but how accurate are the prices given?
I went to BremerFord and got quoted $230 for a part listed as $150?
BA 17682 BP MIRROR HEAD - EXTERIOR REAR VIEW, RH, PAINT TO SUIT, (-)FAIRLANE/LTD/GHIA $150.00
aussiedv8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2007, 03:15 PM   #38
russellw
russellw's Avatar
I have increased the results to 40 and may well up it to 50 - the best way around too many results is to either select a variant model or use more text in the search.
Russ
Old 16-05-2007, 03:15 PM   #39
russellw
russellw's Avatar
As stated when we uploaded this (2 years ago now), they were current at the time at TRADE level so we'd expect some of them to be getting a bit dated by now.
Russ
Old 16-05-2007, 03:44 PM   #40
OED666
OED666's Avatar
yep, definitely useful.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2007, 07:21 PM   #41
Falchoon
Falchoon's Avatar
Originally Posted by russellw
Quote= aussiedv8
Russ
Yeh I was going to mention something about the prices but figured this was probably the reason. Probably best to double the quoted prices to get a more accurate 2007 retail price. Better to over estimate the prices IMO so that when you actually go to buy them and they are cheaper it is a nice surprise!
The other slightly (!) annoying feature with the parts database is needing to put the spaces in when searching by part number.
Falchoon is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2007, 01:30 PM   #42
Sapper
Back to the AU
Sapper's Avatar
I don't know if this is possible, but would it be a huge improvement if you could write code into the serach engine so that when you type in multiple words into the description box it searches for those words in any combination. At the moment, it seems to only search for the exact combination of words entered (including punctuation).
To test this i typed in "camshaft intake" into the description box and returned no results. I then typed in "camshaft, intake" which is, symbol for symbol, exactly the description of a part and it returned one result. This was done under the BA model filter.
Old 29-05-2007, 03:55 PM   #43
russellw
russellw's Avatar
Because it is a text search it takes the text string entered and passes it through to the search engine. It would be difficult to make it heuristic as the functions available within the database structure are a bit limited. Unfortunately, the use of descriptions like the one you have shown above are generally those used within the Ford system and they don't always make logical sense. The best option is generally to search with as few terms as possible as this minimises the possibility of missing a comma or some other form of punctuation that has been included in their description.
Cheers,
Russ
Old 13-01-2008, 08:36 PM   #44
wodahs
wodahs's Avatar
had tried it but at the time it didnt do ba parts will be trying it again now
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2008, 08:37 PM   #45
olfella
Cranky old bastard
I used it a few times but give up in frustration because of the terminology used ( and this was explained in a previous post) Therefore I think sections with part numbers that could then be used to search would be fantasic for blokes in a similar boat to me. Still a worthy tool to have.
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2008, 12:27 AM   #46
jakkes
jakkes's Avatar
with out clicking the link provided were on this site do you find it?
is there any other things like this that this site is hiding from me
also who or what is Altavista Spider found in who is on line?
jakkes is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2008, 01:02 AM   #47
russellw
russellw's Avatar
We will be doing something a little better than that in the near future so keep an eye on this space for further news.
Russ
Old 14-01-2008, 01:04 AM   #48
russellw
russellw's Avatar
There is no other way currently but we will also be changing that in the near future by better integrating it into our planned upgrade.
There probably are other things hidden but they are probably supposed to be!
The Altavista spider is the term given by vBulletin for any spider it can't recognise. Spiders are robotic tools that search the internet so that when you perform a google or similar seach the data can be retrieved.
Russ
Old 14-01-2008, 10:30 AM   #49
whales
351 Cleveland:Pure Muscle
whales's Avatar
Like a few others I didn't know it existed but I think is a great idea and will be using it all the time and I agree with the picture idea but imagine it would be a lot of work but would be the icing on the cake so to speak.
Keep up the excellent work guys
whales is offline   Reply With Quote Multi-Quote with this Post
