Old 02-01-2008, 08:44 PM   #31
Mechan1k
Mechan1k's Avatar
Originally Posted by b2tf
Wrong. It was not dropped in AU2 at all, parents old AU2 Fairmont 6 cyl had one, my ute has one (S3 XR8), and I have seen numerous AU3's that do have them.
The fail safe cooling method that you describe of cylinders shutting down was present on all models regardless of series, it was not implemented to cut out the sensor.
Rog yours being a Fairlane I thought it would have had one, its not hard to put one in, you just need the sensor and a new header tank.
I do have to add to this ... all EGAS models didn't have the failsafe cooling system implemented due to backfiring when shutting spark to Cyl 6 (and kicking back in again.)
My AUII XLS ute doesn't have a low coolant sensor in the header tank ... although it is an I6 though.
I can understand yours having it Austin ... because it's an 8.
Old 02-01-2008, 10:17 PM   #32
FGII-XR6
FGII-XR6's Avatar
there are a few S2 and 3 cars with them but they have been retrofited. the failsafe did come in earlier than the ditching of the sensor . they decided to delete the sensor after the system had run for a while to save $$$$$$$$$$$$$$
Old 02-01-2008, 10:54 PM   #33
Papa Smurf
Papa Smurf's Avatar
WRONG!!!! AUII and AUIII had the sensor fitted. Standard on Fairmont and Ghia and Fairlane 6 cyls. Don't know where ya get your info from but Ford had been fitting them since AUI's and I have been selling them for a few years now. ALL BA's have them as well.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 10:56 PM   #34
Mechan1k
Mechan1k's Avatar
How can all BAs have them ... i bought a 2nd hand BA header tank to replace my AU one ... and there's no sender in the side of the header tank at all.
Old 02-01-2008, 10:58 PM   #35
Papa Smurf
Papa Smurf's Avatar
Maybe it wasn't a BA tank?
Having said that, I will check tomorrow when I go to work. It has been my experience that all have them fitted but I have been wrong before. I do work for a Ford dealer and sell spare parts so I will check.
PS; not wrong about the AU Sensor though.
Old 03-01-2008, 08:25 AM   #36
tf1
tf1's Avatar
Default the final answer
to MRredxr347.I must have wasted my 28 years working in the motor industry for FORD dealers In parts.10 posts the reason not to post is because of misinformed people with tunnel vision.
To answer you all low coolant sensors have been in coolant reserviors since EA falcon but not in all vehicles S pack,XR and higher series were standard but in BA all models have it. Do not confuse this with a engine coolant sensor which tells the PCM at whattemp the engine is. :
FORD will be no1 again as the rest suck!
tf1 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2008, 08:45 AM   #37
tf1
tf1's Avatar
Default ooops
Got to set the record straight on BA falcon "WE WERE WRONG" this model does not have a coolant low level sensor in the header tank. :
Old 03-01-2008, 09:03 AM   #38
RG
Back to Le Frenchy
RG's Avatar
WTF, I was the one who said not to have a go at someone for only having 10 posts and you have a go at me.
I have a feeling that this sensor might be like the tailshaft in manual EL's where some got the balancer on the front of the shaft (manual shaft) but some didn't (auto shaft on a manual from factory).
Old 03-01-2008, 10:06 AM   #39
FGII-XR6
FGII-XR6's Avatar
as you were with series 2 /3 AU
Old 03-01-2008, 01:16 PM   #40
Mechan1k
Mechan1k's Avatar
I could have argued the point ... I know it doesn't though ... I have one installed in my AUII ute ... it was easier to get a BA header tank and the larger hose to the radiator ...than to try and find a clean AU header tank.
All the BA header tanks i saw had no sensor.
It's a surpringsingly nice swap over ... and gives more room around the LPG converter on EGAS models ... as the return hose to the radiator is in front of the header tank and not below it.
Old 03-01-2008, 10:40 PM   #41
Papa Smurf
Papa Smurf's Avatar
Mechan1k, sorry I lead you astray and I had thought they were fitted truly?
I went and checked a new one this morning and NO hole
Mr AU3XR6, you are DEAD wrong about the switches in AUII and AUIII, we have many taxi drivers come into our parts department who buy them for their AUII and III's and I am sure they didn't all go out and get them fitted just to pi** someone off?
I would LOVE to know where you got your Info from? maybe you know something more about Falcons than anyone else or maybe you work for Ford? Anyway, maybe ya need to get the facts straight about that and admit ya wrong, I did
Old 04-01-2008, 07:49 AM   #42
tf1
tf1's Avatar
To RedXR347 sorry you did defend what my answers to the people of a lesser intellect.This crap has been going on for too long its time for mr au3xr6 to accect the fact that there are people in this world with more of the correct information than some misguided and ilinformed facts not relevent or correct.
:thebirds:
Old 04-01-2008, 10:40 AM   #43
b2tf
not here much anymore
b2tf's Avatar
:thebirds:
Maybe so but I think we're done with this. No need for us to continue.
2024 F150 XLT
Old 04-01-2008, 10:49 AM   #44
FGII-XR6
FGII-XR6's Avatar
Sorry b2tf but i must respond to the above post by tf1. I have seen and worked on AU2/3 XR6 Fairmont & Fairmont Ghia and none of them have had the sensors fitted.
According to my friend at ford parts they are not fitted in S2/3 but many taxi and hire car operators get them fitted to give what they believe to be extra protection. so my facts are not " misguided and ilinformed" as you so rudely and arrogantly put it my facts come from observation and from a ford parts interpreter.
Old 04-01-2008, 01:53 PM   #45
GasoLane
Former BTIKD
GasoLane's Avatar
Jeez, and I thought my pic (post #21) would have killed this on the first page
Old 04-01-2008, 02:26 PM   #46
b2tf
b2tf's Avatar
Ok, everybody has had their 2c. Are we done with this now?
Oi, Bucky, where are you. Can I borrow a padlock?
2024 F150 XLT
Old 04-01-2008, 02:27 PM   #47
GasoLane
Former BTIKD
GasoLane's Avatar
Not done yet...Why aint you at work?
Old 04-01-2008, 02:40 PM   #48
XR8 Uterous
He probably is, he just isn't doing anything :P
XR8 Uterous is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 02:46 PM   #49
b2tf
b2tf's Avatar
spot on indeed :
2024 F150 XLT
Old 04-01-2008, 02:48 PM   #50
FGII-XR6
FGII-XR6's Avatar
ok b2tf i'll drop it now :
