TICKFORD XR6
G'day guys have recently acquired a transmission from another meber of the forum(Gary) not sure of ur screen name mate sorry. but yer the time will be coming to put it in and i would not have the slightest idea of how to do it. So an idea is to put on a bbq day/ install day. This would be out Melbourne Airport way/ Sunbury. would anyone be interesded in this?? or would someone be interested in making a few dollars to help install it with me??
let me know suggestions are all welcomed. Car in subject is a EA falcon 4 speed auto and it is having another auto put in it. the auto going in is form another EA (fairmont) and am told is working perfectly. So a straight sway im told.. Dimi
The Ride:Ford EF XR6 S1 Plans: Slam it on its ***, Sports exhaust( upgrade), Rims, Cam, CAI, Extractors +...
The Drive Line: 4.0L MPI 4speed Auto TICKFORD ENHANCED How she Rides: 15inch XR6 MAGS Sound system:JVC head unit with AUX... 6 Inch in doors,rear with a Vnet 15inch & Infinity 12inch Subs In the Boot Running of a Coustic amp The Mods: Pod Filter, exhaust...... |
EBII XR6
c'mon guys, lets get a few of us around to help a fellow member!
DEVLXR
TICKFORD XR6
What would be needed for the conversion as in parts and tools. i have the Auto transmission and will buy the oil for it anything else needed as in parts? and secondly what tools would be required?
dimi thanks branden
BA Mk2 XR6 Turbo
whats needed
Trans Oil Trans Service Kit (optional but i would do it) Plenty of rags Jack or Jacks Car Stand (as in to get height under car like ramps or something) Sockets Extension Bars Breaker bar for the tight bell housing bolts Spanners umm that about does it i think brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter |
TICKFORD XR6
thanks alot for that. is there any gasket between the engin block and transmission? if so would i need to purcahase one of these?
dimi
BA Mk2 XR6 Turbo
umm not from memory. so you should be all good.
in the service kit you get a new trans sump gaskit. so you should be all good service kits can be purchased at any major auto shop. just tell em its a ford and what model trans you have (ea or ea-el or etc) brad
TICKFORD XR6
ohhh ok sweet now just gota look at getting some people together to do it. looking at the 5th of january atm.
dimi
Living the dream
I'd be up for a BBQ/repair day, just give me a bit of notice.
Oh, and I require stippers and booze on arrival ![]() |
#9 | |||
EBII XR6
![]() 5th should be sweet dimi, so far i should be able to make it. I've got a socket set up to 23mm and spanners up to 19mm, I can also bring a jack if need be.
DEVLXR
Parts bin special
I should be able to help with that. Unless anything major comes up, I should be there
TICKFORD XR6
thanks guys for all the positive feedback and sounds like a good plan at this point. i have numerous number of jacks ( the normal car ones) and a set of ramps and 2 car stands. as far as tools go i have some but not as sure where they are
dimi thanks to all who have help thus far
Dimi,
While you've got the box out it would be wise to put in a new rear main crank seal, if it hasn't recently been done. Old seals have a habit of starting to leak after a gearbox change, then it's pull the box all over again. Peace of mind only costs a few dollars extra. Merry Xmas, hope all goes well. Paul |
#13 | ||
TICKFORD XR6
thanks mate i duno wat that is exacterly but will look into it
same to u man merry xmas dimi
#14 | |||
Parts bin special
#15 | ||
TICKFORD XR6
thansk alot guys looks like this little plan might be on hold for a lil while as some other things have come up.
sorryu all dimi
