Old 27-11-2007, 03:17 PM   #1
au^dude
au^dude's Avatar
Unhappy I think my transmission is gone....
Hey just a few days ago my transmission has started leaking oil. I have been given it a fair bit over the last few years as i manual shift it almost all the time. It has been felling sluggish over the past few weeks. Is there a gasket on it that might just need to be changed or new transmission? What could be the problem? Also is it better to keep it auto or change it to manual?
Thanks
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 04:19 PM   #2
waggaclint
waggaclint's Avatar
there are a few spots they can leak oil....pan gasket...extention housing gasket & seal... reverse servo gasket.... front pump seal////selector shaft seal....take your pick as for driving it manually ideally you should just leave it drive if ya want to last.....but manually now and then wont hurt it to much....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 05:08 PM   #3
Dark Horse
_Oo===oO_
Dark Horse's Avatar
I don't think you'll be up for a new box yet - it's sluggish because it hasn't got enough fluid left in it to operate normally. Seals normally tend to go after 100,000 km's or so anyhow.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 06:00 PM   #4
au^dude
au^dude's Avatar
well i will admit that i give it alota so i duno. the box has got round 75xxx on it but den again i got it at 50xxx so its had a hard life lol.
Old 27-11-2007, 06:08 PM   #5
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
I would be checking fluid level first and maybe even draining it and filling up with fresh stuff.
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 06:33 PM   #6
mik
mik's Avatar
sounds like an auto service could be in order.
Old 27-11-2007, 08:16 PM   #7
V8falcons
V8falcons's Avatar
The AU GHIA we picked up last week with supposedly 60ks on it has a leak at the sump gasket and rear output shaft seal, just do a service on it for(repalce oil/filter sump gasket) see how it goes,Thats Alot cheaper than a replacement box,(manual or auto).
Good luck
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 09:40 PM   #8
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Manual shifting down the gears in the end you will destroy the clutchs. My brother had his rebuilt and about 6 months later it was rooted because of maual shifting DOWN, manual shifting up shouldnt do to much at all. But theres no point as when you give it a boot the auto will rev it out all the way anyway. As for the sluggish does it do it more when its cold??? a gearbox that has low fluid will slip more cold then it will hot
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 11:53 PM   #9
au^dude
au^dude's Avatar
like the car just does not feel right. It doesn't go as hard as what it use to. Gonna get a service tomorrow well see if it fix's it.
Old 29-11-2007, 07:49 AM   #10
naughtyfalcon
so what is the result
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
