Old 25-09-2007, 06:07 PM   #1
Grechie
Grechie's Avatar
Default The Additive To Oil To Break It Down
Hey guys
Im after the name of the stuff that you add to your engine and it breaks up the oil and gunk that sticks inside
and also where can you buy it ?
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2007, 06:13 PM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
"Engine flush" or words to that effect. There are probably 5 or so brands that sell the same sorta thing.
Old 25-09-2007, 07:06 PM   #3
V8falcons
V8falcons's Avatar
Kero will give it a good clean
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2007, 01:01 PM   #4
Ringo
I see you....
Ringo's Avatar
oooooooo yes it will but you want to just leave it idling while running the kero through.
Taking it for a drive and loading up the engine with thin oil is a recipe for....a rebuild.
If you have a serious amount of sludge it will take multiple flushes over time to dissolve it.
Ringo is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2007, 01:19 PM   #5
PoMmYwOG
i've found a few hundred ml of diesel does the trick...just let idle for a while and it will drain like water...
10' FG XT in Edge (Company Car)
6Spd ZF!!
06' Mazda SP23
5spd auto
Luxury pack
PoMmYwOG is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2007, 01:23 PM   #6
Tote
Tote's Avatar
http://www.costeffective.com.au/sol1.htm
That may be the stuff you are thinking of
Regards,
Tote
Go Home, Your Igloo is on Fire....
Tote is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2007, 06:15 PM   #7
FrogInASock
Getahaircutandgetarealjob
If you have access to some *ahem* oil made for diesel engines will clean gunk. But if left for too long in your petrol engine, it'll start to leak out of just about every seal!
Te pilos recidene volo et opus solidus capere :
FrogInASock is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2007, 11:49 AM   #8
Lightning Strike GT
Lightning Strike GT's Avatar
Give it a couple of Kero baths
About 1/2 to a 1 litre of kero to the oil when warm and let it fast idle for about 10 mins and drop it immediately.
Drain it and put some cheap oil and filter in it for about a week and do it again - the new oil will be black as when it comes out.
Do this a couple of times over a few weeks if the motor has been neglected
When you are satisfied that the oil is coming out rather clean refil with your fav oil and oil filter and change every 5k
Regards Alan
FG GT in Lightning Strike
5th anniversary edition in manual 1 of 25
And an 2019 MD Mondeo Trend Wagon in Platinum White
Lightning Strike GT is offline   Reply With Quote Multi-Quote with this Post
