Old 22-08-2007, 09:03 PM   #1
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Default Leaking XR8
We wait for ever for it to start to rain up here in QLD and when it does i get in my XR8 and the passenger side front floor is wet. Is this a common thing or does anyone have any idea were the water may be coming from. I dont want to pull the dash out cause its a pain in th A$$ but i dont want my XR to rust from the inside out either!!
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2007, 09:50 PM   #2
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
How is the seal in the front window top centre, as some off them have a small slice were they are joined.
Not to sure if it is common but my mate who had a au xr6 series 3 had the same problem before the window was replaced.
I havent had it yet but i hope it dosent happen anytime soon and also hope you can source this problem before it causes other issues.
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2007, 10:05 PM   #3
DaveTE
Back in black
DaveTE's Avatar
Same prob in mine XR8 S2. A ot easier than pulling out dasshes to check as well.
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2007, 12:13 AM   #4
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
the seal dosn't look like its sitting right so it might just be that. Cheers!!
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 23-08-2007, 12:19 AM   #5
DOC
DOC's Avatar
The rubber seal on the AU XR ( not sure probably all models ) was prone to cracking and is common, you will find they let go with temp change, ie cool days then a hot spell or vice versa, due to a poor rubber used than did not take to the extreems.
I doubt warranty work would still be in with the AU ? but to get original seal back they will need to replace the wndscreen, otherwise they will use a crappy generic rubber across the top with silicone.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2007, 01:42 AM   #6
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
yeah its been pretty cold up here at night time and no rain for months then all of a sudden this week has been like a cyclone and my car is like a flash flood!!! ill do the windscreen and hope thats it.
AU3 220 XR8
CUSTOM PEARL PAINT
ADVANTI 20's
K&N
PORTED MANIFOLDS
244rwhp
NOW WITH T5 5 SPEED
SUZUKI GSX-R 750
BLACK 2007 MODEL
Old 21-09-2007, 01:09 AM   #7
Firebell AU3SR
Firebell AU3SR's Avatar
Hi mate, just wondering if you had any luck with the leak !as my au3 sr sedan has started to leak from under the dash next to the glove box when it rains heavy wetting the floor mat.The windscreen seals look all ok.I think the water is coming in from around the fire wall.Thanks Steve
Firebell AU3SR is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2007, 08:44 AM   #8
Sledgehammer
Sledgehammer's Avatar
Common as this is. I need mine done too.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
