Formally FairmontPom
Where can I get more info on the aftermarket camber/castor adjustment kits for the AU ?
Had new front tyres fitted today (Federal SS 595s) and noted completely bald/scrubbed out inner treads on the old ones. I had a 4 wheel alignment and balance completed at the last service, which was around 6,000 kms ago or around 9 months, and nothing untoward was pointed out to me then. Is this an age related issue as the car slowly 'sags' with age and use? The Bob Jane guy today told me you cannot adjust the camber on these cars, and have to retro fit a kit to facilitate dialing out the negative camber ? Any ideas of cost in carrying out this mod, as I'm considering it so my new tyres don't look the same in 12 months time ! Cheers. |
Sales Representative
We do the repairs ourself... the reason why some camber kits needs to be replaced is due to short threads from factory and this doesnt allow enough adjustment in certain situations... Ebay has some good parts and is usually well priced, Powermax is one brand name that comes to mind, my father used them in his EB wagon with great succss.
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
#4 | |||
Could be more to do with the bushes at the very front on the lower arm that stops the wheel moving back when you brake. What happens when you brake is that the wheels try to move back and point out. This is what wears the inside edge off the tyres.
These bushes are a fluid filled rubber that perishes and AU's have reached the age where, with average kays, the rubber cracks and looses the fluid. So the wheels move back when you brake. Nolathane and others do make a nylon replacement but these are known to go brittle & crack after as little as 12 mths so the OEM part is the go Howesy - you will more than likely find this is your real problem and the guys are over compensating with the toe in to correct it when the wheels do move back
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#6 | |||
#7 | |||
Got a Similar prob on my BAII XR8 Ute the insides on the front are wearing unevenly. Basically i'm getting a little over 25K out of my original Tyres with the inside on the fronts almost scrubbed out by that point. Mines lowered about 33mm used King Springs I've been told I might need a camber kit for her what do you guys suggest. |
#8 | |||
the fulcrum item is a very sturdy piece of kit
its a shim type so wont go "out" of adjustment unless the bolts are left loose and the shims fall out(if that happens id be sueing the place that did it for negligence !!) ask around your local area for a REAL EXPERIENCED wheel alignment specialist they should be doing a full roll out type test as a toe only test that bob jane does is no good for our cars given the camber issues etc.. on a side note.. how much are these OEM spec front bushes?? and do you need to get them pressed in?
Thanks for the info guys, I'll keep a careful eye on things and probably start pricing up the kit...
...although the wife now wants me to sell the car, and get her a 4x4 :togo: |
