Old 05-09-2007, 12:51 PM   #1
DAMO 58
Previously TUNGA
DAMO 58's Avatar
Default ghia ride height
I know that this question has been asked before .my 75th annerversary ghia has factory 17 inch rims but dose not have xr6 ride height .wot would i expect to pay to get it lowered to a height that looks good but wont scrape on every bump or drive way that i go over .Also any reccomedations where to take it .Iam in ferntree gully in vic.
regards
Damo
DAMO 58 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 01:18 PM   #2
xr8 007
xr8 007's Avatar
to do it properly u would need to change front and rear springs, and rear shocks. looking at around 250 (give and take) for the front springs and the same for the rear.
take it to pedders and other suspension places and get some quotes
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 01:22 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
From memory, the job on my car was about $1,500 for new springs, shocks, a caster / camber kit and new wheel alignment. It was lowered to XR height.
I have the heavy duty tow pack and the towbar scrapes on some driveways if I have rear passengers.
Someone else might be able to recommend a place to get it done.
Old 05-09-2007, 01:42 PM   #4
V3RSAC3
... Fear it!
V3RSAC3's Avatar
what state u in?
Originally Posted by Mr Hardware
Just remember gents, anyone can follow fashion, but it takes someone with real class and finesse to have Style.
Chrysler 300C Sedan
SY Territory Ghia
V3RSAC3 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 02:08 PM   #5
DAMO 58
Previously TUNGA
DAMO 58's Avatar
i am in ferntree gully victoria
Old 05-09-2007, 05:00 PM   #6
2Lucid
ive got a 75th ghia also..... when u lower it dont forget to put the XR camber pins in the end otherwise ull scrub tyres..... mines reasonably low but doesnt scrape check out my pics http://www.aufalcon.com/cgi-bin/inde...act=item&i=323
2Lucid is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 05:37 PM   #7
DAMO 58
Previously TUNGA
DAMO 58's Avatar
thanks lucid looks good .wot springs did you use
Old 05-09-2007, 10:38 PM   #8
2Lucid
give me a day and ill find out and let u know.... i know its the second set because the first ones werent right.. ill try and get a manufacturer and part no. for ya
Old 05-09-2007, 11:24 PM   #9
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
the XR's were only an inch lower than factory if i remember right. At only an inch you could probably get away with just springs and not worry about shocks. I did my wifes forte with king springs i went inch and a half and left standard shocks that was 3 years ago and havent had a problem. I also did that camber kit it was about 250 from memory at bobjane or one of the tyre shops... it dosnt scrape much at all.
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
