Old 10-08-2007, 09:01 PM   #1
jaydee
jaydee's Avatar
Default Hate that wet patch!!!
No it's not what you're thinking.
Got into my XC (that I've had since Adam was a boy) after it was sitting in the car park at work all day in the rain, and found a wet patch in the carpet on the drivers side.
Best I can tell it looks like its running down the plastic kick panel.
Must be leaking from under the windscreen or something, not a good sign, means I'm going to find a big rust hole somewhere, bugger.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2007, 09:11 PM   #2
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
Sounds like a similar wet patch i found in my XF, for some crazy reason i decided to take it through an automatic car wash.
Damn floor carpets on both sides start to move about like they were alive and got quite wet....so suffice to say, i never did that again lol
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2007, 09:19 PM   #3
seXCmont
EcoBoostin
seXCmont's Avatar
My XC had a bit of water coming through the windshield. i got some auto silicone from work and under this heavy rain and car washers it hasn't happened since.
seXCmont is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2007, 09:30 PM   #4
jaydee
jaydee's Avatar
Thanks guys, I'll be pulling the windscreen trim off tomorrow and check it out.
jaydee351
4DV8
Old 10-08-2007, 10:56 PM   #5
[Tonko]
What's green is gold
[Tonko]'s Avatar
I have to put up with both types...
But at least with one, i can move to the other side...
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2007, 12:02 AM   #6
Shambles
Knucklehead
Shambles's Avatar
Check that your scuttle panel in front of the windscreen hasn't filled up with leaves and mud. This causes the drain to block which then allows water to back up and flow inside through the air vents.
Happened to me on my XD ute.
Cleaned out 20 years of crap and it didn't give me trouble after that.
Shambles is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2007, 01:17 PM   #7
Auslandau
335 - STILL THE BOSS ...
Auslandau's Avatar
Pull the guards off first! It will be the plenum rusting. This is 99% of the course and pulling the trim off wont see the problem.
| [/url] |
'73 Landau - 10.82 @ 131mph
'11 FG GT335 - 12.43 @ 116mph
'95 XG ute - 3 minutes, 21.14 @ 64mph
101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong!
Clevo Mafia
[SIGPIC][/SIGPIC]
Auslandau is offline   Reply With Quote Multi-Quote with this Post
