Old 29-07-2007, 10:37 PM   #1
fastleno
FASTLENO
Default Tickford AU VCT piston clearances
anyone know the standard clearance between the piston and the bore?, i brought a motor and there seems to be a heaps of play in the bore (heads off)
fastleno is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2007, 08:42 PM   #2
fastleno
FASTLENO
BUMP...... anybody have a AU bottom end that can stick the feeler guages in for me, please.
Old 30-07-2007, 08:50 PM   #3
FGII-XR6
FGII-XR6's Avatar
0.010 to 0.130mm according to the manual
Old 31-07-2007, 12:33 AM   #4
FGII-XR6
FGII-XR6's Avatar
sorry typo should be 0.010 to 0.030mm according to the manual
Old 31-07-2007, 09:34 PM   #5
fastleno
FASTLENO
thanks mate, this thing has like 2 mm
Old 31-07-2007, 10:08 PM   #6
FGII-XR6
FGII-XR6's Avatar
not good
Old 01-08-2007, 06:07 PM   #7
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
The piston will always move in the bore from side to side as the top of the piston is about 0.080'' or 2mm smaller at the top in the ring lands, it will be fine it should be nice and free, as the AU's have a very shallow piston skirt it will move about 1mm or so up on the crown anyway.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2007, 09:14 PM   #8
fastleno
FASTLENO
should i be able to see the rings clearly, seems excessive but i haven't had the head off a au before.
Old 01-08-2007, 10:46 PM   #9
NeishaXR8_347
SS Grunt
If its clean and not all carboned up then yes if you look closely and with a torch you would most likely be able to see part of the top ring.
Old 01-08-2007, 11:18 PM   #10
fastleno
FASTLENO
so basically i would have to remove a piston take the rings off and put the piston back in and then use the feelers so as i can get below where the rings are for a mesurement
Old 02-08-2007, 04:48 PM   #11
NeishaXR8_347
SS Grunt
you need a proper bore guage to measure properly, a feeler guage is only rough, i wouldnt bother unless your gonna do something about it when you see Fords more then generous piston to bore clearances.
Old 06-08-2007, 10:13 PM   #12
fastleno
FASTLENO
any of you guys know how much gap should be in the rings ? i have taken off one of the comp rings and slid it down the bore and the ring has a far gap, doesn't look right to me
Old 06-08-2007, 10:58 PM   #13
redef
redef's Avatar
sorry to get off topic but does anyone know piston to valve clearance on intech? thanks
redef is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2007, 08:48 AM   #14
NeishaXR8_347
SS Grunt
well for my build i went 0.020" on TOP and the Second compression ring. You wouldnt want much more then that unless your running some serious boost or nitrous.
Old 07-08-2007, 11:05 AM   #15
fastleno
FASTLENO
thanks for you help mate, the guy that rebuilt it is a qualified mechanic and has put it together with 6.0+mm gap in the rings (that anit a typo the dec point is after the 6mm), makes me wonder, at a guess i recon he has used EB of EF rings
Old 07-08-2007, 12:30 PM   #16
NeishaXR8_347
SS Grunt
Sounds like he has done something stupid and put EA rings and or pistons into a 4.0L style block, its only 0.030" differance in bore size but would be why your saying you have so much gap and piston movement. Anychance you can get up some pics?
Old 07-08-2007, 12:33 PM   #17
NeishaXR8_347
SS Grunt
With 6mm ring eng gap clearance which is 0.240" is 0.220" more then you would want. With 5.5mm more then you want it would be a very low compression engine and would blow some serious clouds of smoke. Not to mention be gutless.
Old 07-08-2007, 04:37 PM   #18
fastleno
FASTLENO
thay are defiantly AU pistons must be the rings that are incorrect, the reason for the pull down was because it was meant to have a crook head gasket, when the head came off the pistons where covered in oil and even the block and head faces where coated in oil, what part did you want pics of ?
Old 07-08-2007, 06:48 PM   #19
FS5
i don't know about piston to bore clearences ,but when you check and see the bores are worn .you need to slide a ring (preferably a new stock size one) down the bore a few mm keeping it square to the top of the block.then you measure the gap between where the two ends of the ring joins .
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
