Old 06-08-2007, 08:40 PM   #1
Stav
Smile
Stav's Avatar
Default Misfire solved after 3 months looking!!!
I was plagued with an intermittent misfire for the past 3 months.the cars power is great.The problem have been fighting with is a stumble or misfire off idle when accelerating from a stopped position . I had a very strong feeling it was fuel. I had emptied the tank,cleaned it.Changed the fuel pump,changed the injectors,changed 2 fuel filters,cleaned the injectors,replaced tps,ego,isc,coilpack,leads,plugs ,checked cat,checked fuel pressures while driving.
It was getting very dangerous.Tonight I turned the pressures right up on my big injectors and voila not only is the hesitation gone but throttle response is alot better!!Just like the standard injectors!!
Old 06-08-2007, 09:18 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
Sweet what was the std pressure and what its set at now????
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2007, 09:22 PM   #3
Stav
Smile
Stav's Avatar
Standard injectors were at 39 psi. My bigger ones at 45 psi.This was not enough to keep the problem away.Now at 55 it seems good.
Old 06-08-2007, 09:26 PM   #4
svo347
AFF's 1st DM.......
svo347's Avatar
Did you have it connected to an af meter? any downsides ? ie pulse width etc
13.21 @107.7mph
