Old 28-07-2007, 09:38 PM   #1
roddo
METEORITE S3 XR8
Default Fitment of 351 windsor to AU XR8
I was wondering if there is anyone that has fitted a 351 windsor into the AU XR8 as i am looking to do this to mine but am unsure of the differences between this and the 302 that came in it .I am aware that the inlet and exhaust manifolds are different but what else is E.G sump and any thing else
roddo is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2007, 10:28 PM   #2
HLC
Audi S3
better off stroking it to 347.
there are a few users on here that have done this.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2007, 11:00 PM   #3
roddo
METEORITE S3 XR8
have thought about the option that you mentioned but then found out you can stroke the 351 to 408 this is my intension at the moment but that could change if it gets to hard with too many diferences
Old 28-07-2007, 11:06 PM   #4
Casper
Contributing Member
Casper's Avatar
yep, been done:
www.aufalcon.com/sledgehammer
Older, wiser, poorer.
Old 28-07-2007, 11:17 PM   #5
roddo
METEORITE S3 XR8
have seen this but was looking to keep the factory apperance as in the plenum am aware that the lower half is different on the 351 to the lower on the 302
Old 28-07-2007, 11:21 PM   #6
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
Did you watch his dyno run MY GOD!!!!!!!!
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2007, 11:31 PM   #7
roddo
METEORITE S3 XR8
yes i did and that is what made me look at the option
Old 29-07-2007, 08:08 AM   #8
Sledgehammer
Sledgehammer's Avatar
I ran an EFI 351W both with and without a vortech S/C, before going in current direction, the engine fits in the bay just 1 inch taller in height, all pulleys need to be amended to space out to line up, you need a 351 EFI lower their are a few available, (Ford M/S, TFS etc) you will need to have a set of extractors made up as the 302 ones dont fit back in again, you need a sump made to fit, you need to convert block to rollor can if you want to go this direction or use the retro fit lifters, you will need to think bigger one all counts. pm me if you would like any details etc.
You also need to sort out the timing issues with either a dissy blank or something like the msd unit, their was a kit made in the states a while ago for this as well. I ran a dizzy shaft with no cap modified to give a crank angle trigger to aftermarket computer
I would go the stroker if I were to do this again with a motorsport block that you can also stroke out just as far these days check out the new 'Boss' motorsport block.
Also if you want to run it on the street you may have some concerns with rego and insurance etc so best check these as well.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2007, 09:05 AM   #9
roddo
METEORITE S3 XR8
thanks for that it now sound way too hard but it doesnot matter as it was only a thought i may as well go the stroker then and look at fitting a super charger then thanks for the input
