what are the common problems with ED Fords because i just want to know the common problems can you list any common problens because there are a few with vn-vs holdens.
also if the bcm stops can i just replace it with any ed fairmont bcm with another ed fairmont bcm and the car will start and the same with the ignition switch/barrel and ecu or are they all linked together |
Head gasket usually blows every 100-150 thousand k's. (If looked after proerly should last ages)
Brake switch (forgot exactly what it's called) That's all I know of. |
Head gaskets yup thats one and the brake switch both correct also the ed may make you become sexified in the eyes of women so be careful on that one.
i got ed ford fairmont.i only had to do the head once in its life and rotors.that it.
thay are good ride to have. stef |
bcm???
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
low wagooon
BCM is body control module. If its not broken dont worry about checking it. Transmission could be another thing to watch out for. Just take it for a drive. See if it shifts smoothly. I'd recommend getting an auto service. Unless your lucky enough to have a T5. Head gaskets dont always go every 100 to 150,000 as previously stated. They go when ever they go. Im on 329,000 and stil original. Just check to see that its not loosing coolant or the oil isn't a milky colour
Webby
S2 AU XR6 UTE |
ED's don't have a BCM, I think you are talking about the Smartlock Module.
so for example if i had a ed fairmont smart lock module if i went to put another ed fairmont smartlock module do i have to get that linked to the ecu and ign barrel for the engine to start or if i replaced the ign barrel would i have to get that linked or if i had a new ecu would i have to get that linked so do the ign barrels, ecus, and smartlock modules have to be programed together for the engine to start
oh I found that the abs doesnt work for me... weather this is common or not is another issue. Does anyones abs thats "working" lock up??
Hamish ![]() ED, Lowered Lovell Springs, Monroe GT gas shocks, SAAS Racing Buckets, SS Lab Sound System, Carbon Fibre Wheel, Full Sports Exhaust System. |
Are you planning on pulling a heist on someones car? lmao
#12 | ||
no im not hoisting someones car i just want to know if i can just replace the smartlock module, ign barrel and switch and ecu or do all 3 have to be linked for the car to start because i might get one my self
