I wanna XR5
Is there a LSD for the manual LS focus?
2007 Ford Focus Zetec
I don't see why not, but I haven't seen any around.
You could use the phantom grip LSD kit, but they are known of blowing the gearbox casing. |
Posts: n/a
I've often thought this myself. Though LSD and FWD aren't the best things to mix, unless you like lauching in straight lines a lot.
There isn't one from the factory, but i think the Mazdaspeed 6speed box could have it? Otherwise what extremist said |
AFF Post NAZI
what gearbox are you guys running?
cause i know there is a Quaife one for the IB5.....just not sure what you guys use. they also assist in cornering....
Quaife make LSD for the LR Focus so I'm sure that they would make a LSD for the LS Focus....should do a search on the Quaife website
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
#6 | |||
Posts: n/a
#7 | |||
Old enough to know better
