Gday,
It looks like I might need to replace my gearbox - normally a fatal problem on a $1000 car BUT, I've found a cheap one which could fit... It's a 5sp. box from a 1.6lt carby KH Laser. My car is a 5sp KE carby. Would the KH box fit in my KE? Cheers. |
Over Thinker
have to wait for a laser guru to respond to that one
5 speed to 5 speed ok ring a ford wrecker for a quicker answer its the clutch spline and do the housings to the motor and bolt holes match up next the length of the cvs drive shafts best get out the tape measure dont forget to put in new cv joint seals on the box :togo:
My car goes Brumm Brumm Last edited by dirty hands; 25-06-2007 at 10:23 AM. |
#3 | |||
What a performer!
They're like $150-$200 from any U-PULL-IT/PICK-A-PART type wrecker. Cheap and common. Anything but a fatal problem. ![]()
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
