I bought a $45 wrench from autobarn and it hada little plastic thing that sat inside a hole on the side of the the torque wrench.
That has now gone missing, it still clicks but is it reading right? I need to tighten up my exhaust manifold and according to the wrench they needed around 1/2 a turn. |
ORSM FORD CRUSIERS
exhaust manifold.... just tighten it up
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#3 | |||
Bad Music and Litre Bikes
If its plastic, I can't see it being used it the torque settings of the torque wrench. Mine hits metal on metal so that it doesn't get dinted or and change the settings.
Does anything hit or touch where the plastic thing was? Did it stick out at all?
XY Wagon - NAKED! Quote:
low wagooon
If you have been using it to undo bolts it may be out of calibration.
Webby
S2 AU XR6 UTE |
The little plastic plug covers the adjustment screw used for calibration. As long as you don't move the screw it should be reasonably accurate.
