Old 12-06-2007, 01:33 PM   #1
Rhubarb
Default XR4 tune for Focus Zetec?
I read today that the XR4 goes on sale today with a "tweaked" version of the focus motor delivering greater power and torque than the standard focus motor.
Quote from the article:
The 2.0-litre Duratec four-cylinder, borrowed from the garden variety Focus, has been tweaked to produce 110kw of power, up a meagre 3kW on the Focus engine, but with a much flatter and broader torque profile.
The XR4's peak 190Nm is reached at 4500rpm, but with 80 per cent on tap at 1500rpm and 90 per cent available from 2200rpm through to 6150rpm, the flexibility of the engine is impressive.
Full article found here:
http://carsguide.news.com.au/story/0...-21822,00.html
So .... Does anyone know if there is any physical mods to the stnd motor or is this just a retune? If its just a retune how easy would it be to have it done to my Focus Zetec and would ford do it for me under warranty ????
Rhubarb is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 01:50 PM   #2
Polyal
The 'Stihl' Man
Polyal's Avatar
Pretty good question.
SO I assume most would be in the ECU, other than that I have NFI.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 12-06-2007, 01:56 PM   #3
Piotr
Non-Regular Member
It has a different exhaust system and different intake.
If you retuned a standard Focus motor you could get more than 3kw and 5nm gain.
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 02:00 PM   #4
BlackLS
I recon its all in the revised exhaust.
Rhubarb, check out the 2 engine mods in my signature, they all owe me nothing but lazy Sunday afternoons and I recon give me more than 3kw.
http://fordforums.com.au/showthread.php?t=101280
http://fordforums.com.au/showpost.ph...1&postcount=26 (ignore the battery part)
Welcome to the forums, make a intro thread.
Old 12-06-2007, 02:31 PM   #5
Rhubarb
Thanks Black LS - interesting mods.
Does anyone know what the torque spread of the stnd motor is, and how this varies with fuel octane?
Old 12-06-2007, 03:40 PM   #6
Miyagi
fordxr5turbo.com
Miyagi's Avatar
You can be confident that Ford Dealers won't provide support on tuning up to XR4 spec... it'd dilute the point of having the XR4 around.
FordXR5Turbo.com | FordXR4.com
Lovin the Focus & Mondeo XR5 Turbo!
Miyagi is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 03:40 PM   #7
BlackLS
I've dont have the rising figures, but it picks up around 2800RPM, peaks torque is at 4500RPM and peak power is at 6000RPM.
Old 12-06-2007, 05:14 PM   #8
Stugots
2006 Focus LX Hatch
Stugots's Avatar
They'd be using the same gearbox I'd imagine?
Stugots is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 05:20 PM   #9
Ives
Ives's Avatar
I know it's been covered before, but isnt Fiesta ST/XR4's engine is from Ford Mondeo? And is it essentially the same engine that's in the LS Focus now?
Ives is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 05:58 PM   #10
zetec
Zoom Zoom
zetec's Avatar
Correct Ives. LS Focus engine with intake and exhaust changes. It feels like a totally different engine and sounds unbelievably better than the vacuum cleaner in the LS.
XR4 uses a standard Fiesta gearbox with shorter gearstick for a shorter "throw".
2012 Mazda3 MPS
Old 12-06-2007, 06:27 PM   #11
photn
AFF Post NAZI
photn's Avatar
Not as short as mine heheheheheh
Old 12-06-2007, 08:10 PM   #12
More revs
And Fiesta weighs 200 Kg less - that's 2 fat ladies and their shopping so XR4 should go almost ok...
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 10:34 PM   #13
Mick K.
Mick K.'s Avatar
Here is some more info...
Originally Posted by Goauto.com.au
It delivers 110kW of power at 6000rpm, while 80 per cent of the 190Nm torque top, which starts to level out at 4500rpm, comes in from just 1500rpm. From 2200 to 6150rpm, there is still 171Nm at the driver’s disposal
This has been achieved via the inclusion of a variable valve intake system Ford dubs VIS that plumps out the available torque, as well as the implementation of a new exhaust set-up that features a revised catalyst for reduced back pressure, as well as a more tuneful tone.
A low-inertia flywheel has also been added for a faster throttle response
http://www.goauto.com.au/mellor/mell...2572F40016FCFD
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 02:04 AM   #14
XtRmn8
Have a look on the Taiwan Ford website. They have the new updated Focus on there and if you manage to get to the specs page you will see that their updated 2.0 Focus is 110kw/190Nm.
Hope Ford Australia sell the Ghia with black leather and chrome interior trim rather then the ugly wood look.
XtRmn8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 09:48 AM   #15
Rhubarb
Getting to the specs page is not that easy for those that don't speak Taiwanese ... namely me.
Old 13-06-2007, 08:15 PM   #16
XtRmn8
I don't speak it either, but the pages are same layout as the AUS pages so I managed to find it.
Here you go:
Focus Specs
148hp/19.4kg-m = 11k0kw/190Nm
Old 14-06-2007, 08:46 AM   #17
Rhubarb
good work !!!
It will be interesting to see what gets released here in September.
Old 15-06-2007, 02:43 PM   #18
More revs
Wouldnt make me wanna trade in my Zetec however.
Old 15-06-2007, 03:43 PM   #19
Rhubarb
What if it also came with Side Curtain airbags, DSC & Traction Control ?????
That was my dilemma. Should I take a Zetec now or wait for the new model with safety features available.
In the end I got an 07 Zetec for $25200 driveaway whereas the new model would have been over $30k.
Old 15-06-2007, 03:49 PM   #20
photn
AFF Post NAZI
photn's Avatar
not bad...
Old 15-06-2007, 09:43 PM   #21
More revs
Good call, if you have say a Vectra now and wanna decent car then the XR4 would be on a short list for sure.
But seing I have an 06 Zetec the XR would not be anywhere near enuf to make me want to change.
We just need some private tuners to come up with locally supplied solutions because theres a whole lotta Kw lurking in that Duratec.
I reckon another 20Kw would transform the focus.
Old 16-06-2007, 04:26 AM   #22
BlackLS
But the same 20kw can added to the XR4! Imagine how much better that would go!
Old 17-06-2007, 09:24 PM   #23
More revs
Hmmm for one of those I would sacrifice some space and rear doors. Ok ok I want one. Soon as I finish killing the wifes vectra...
Old 17-06-2007, 09:36 PM   #24
BlackLS
Have you tried the Vectras inbuilt overspeed prevention system?
The autos have 4 preset speed limiters. Redline in 1st, redline in 2nd etc etc....
Old 17-06-2007, 09:39 PM   #25
Ruger
Bseries Moderator
Ruger's Avatar
If your half serious about performance youll do the air intake and exhaust anyway and youll get a shitload more than 3kw or whatever it was. surely with an intake, header, cat and full exhaust along with a standard tune you would get another 20kw from a 2.0 duratec? what power are the blokes overseas making?
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 06:14 AM   #26
Marshy79
I was under the impression the XR4 had revised gearbox gearing? As in shorter to make it feel a lot quicker than the standard Fez.
Anyone to confirm?
All in all... it comes down to seat of the pants fun. Changing the gearing is an easy way to do that.
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 07:55 AM   #27
Rhubarb
the specs are all available on ford.com.au
Old 18-06-2007, 08:12 AM   #28
Steffo
LPG > You
Steffo's Avatar
Anyone to confirm?
XR4 and WQ Zetec have the same gearing in the transmission, the XR4 has a different final drive, at 3.82:1, its alot taller.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 09:46 PM   #29
Mick K.
Mick K.'s Avatar
Does the XR4 still have 4 x 108 rims that will fit an LR Focus?
Old 18-06-2007, 10:43 PM   #30
Steffo
LPG > You
Steffo's Avatar
Yes it does.
