Old 19-05-2007, 06:33 PM   #1
tabletennisman
tabletennisman's Avatar
Default Removing Door Trim
I'm trying to remove the front door trim from an AU Futura however i can't seem to work out where the last screws are hidden. I've found the 2 on the bottom of the trim, and 1 on the side. The bottom of the trim is now loose, however i imagine the door handle area is holding it in somehow?
Could somebody please tell me where the final screws are!
Thanks!
tabletennisman is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 07:42 PM   #2
XR6Stu
there is one in behind the plastic door handle, and one under the electric window switches. I will try to put a photo up in the enxt half an hour
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2007, 08:22 PM   #3
XR6Stu
ok, i took some pics. I used a butter knife to pry the handle cover and window switch out. ANd here are the pics!
Old 19-05-2007, 08:22 PM   #4
XR6Stu
And be careful not to break the back edge off the window switch like i did lol.
Old 19-05-2007, 10:03 PM   #5
tabletennisman
thanks mate! worked a treat.
The next problem is trying to work out what's wrong with these power windows
Old 20-05-2007, 01:15 AM   #6
DOHC-DJ
DOHC-DJ's Avatar
whats wrong with your power windows, easiest to start off by pulling apart the switch and cleaning the contacts
DOHC-DJ is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2007, 06:06 AM   #7
The Monty
Just slidin'
The Monty's Avatar
If they are slow or not going at all, I buy a tyre blackener (silicon) pad, and slide it between the rubbers. Refreshes there look, and makes them slide like new.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2007, 03:10 PM   #8
Soundwarp
Blue to the bone!
Soundwarp's Avatar
I must ask how do you get the switches off?
BA GT-P in the garage
http://img.photobucket.com/albums/v7...dwarp/fbar.jpg
Soundwarp is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2007, 04:10 PM   #9
Mechan1k
Mechan1k's Avatar
They just pop out ... once the plug is off the bottom of the switch contacts you can clean them easily ... also the individual switch pop out of their place as well.
Just make sure when reseating the plug/connectors that you put them on the right switch :hihi:
Old 27-05-2007, 04:26 PM   #10
Soundwarp
Blue to the bone!
Soundwarp's Avatar
Thanks mate!
