Old 23-05-2007, 07:22 PM   #31
JimmyJ
Originally Posted by NeishaXR8_347
It would seriously be less mucking around if you just get the $4000 Powerdyne blower from CAPA. It comes in a kit.
The CAPA website says $ 6,319.00 for the Powerdyne kits?
JimmyJ is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2007, 07:37 PM   #32
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Yes the site does say that, but if you wait and look in magazines like Ford performance and that they do have them for $4000.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 05:45 PM   #33
sprjenkins
Spr Jenkins
sprjenkins's Avatar
Yeah $4000 for a BA/BF $7000 for an AU. Then you need exhaust, flash tuner, etc Try $10,000 all up.
Getting 220 rwkw is easy. Forged pistons, rods, head work, deck the block for 11.1 compression ratio, run on 120 octane race fuel. big .550+ lift cam, springs, vernier gear, oversize valves, extractors, exhaust, cold air intake, fuel pump, injectors, intake manifold and stand alone engine management and you'll see 220 rwkw easy.
Dont forget to add lsd, diff gears, drive shaft, strengthened box and clutch/torque converter, upgrade the brakes and suspension, new wheels and good rubber and you should be all set.
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands"
-Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times
-Chuck Norris doesn't sleep. He waits.
-Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain.
sprjenkins is offline   Reply With Quote Multi-Quote with this Post
