13-05-2007, 11:10 PM | #1 | ||
Can Some One Please Help.
I Have A 2000 Au2 Which Seems To Be Going Through Batteries.3 In The Last 6 Months. Can Someone Offer Help? |
13-05-2007, 11:13 PM | #2 | ||
it is most likely the alternator ( overcharging and cooking the battery ) with the engine running and a digital multimeter check the voltage should be 13.8 to 14 volts
13-05-2007, 11:24 PM | #3 | |||
Karasu
13-05-2007, 11:36 PM | #4 | ||
My Curent Battery Has Lasted Nearly 2 Month's.
Checked The Battery While Running And Was Indicating 14.4 Volts Yesterday. Today Indicated 14.05 Volts.the Battery I Purchased Has A Maximum Charging Voltage Of 14.8v. |
13-05-2007, 11:37 PM | #5 | ||
Is It A Simply Replacing The Regulator
13-05-2007, 11:47 PM | #6 | ||
yes thats right replace the reg and you should be ok also if you are geting those reading at idle you might find it higher with a few revs onboard if the reg is cactus
13-05-2007, 11:54 PM | #7 | |||
Karasu
14-05-2007, 08:42 AM | #8 | ||
If you use the dah diagnostic mode as well ... you can monitor voltage while driving as well as it is display digitally in your odomoeter area.
