Old 13-05-2007, 12:31 PM   #1
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
Default water pump pully
how do you take the water pump pully on a 4.0 because mine got dammaged
for sale ======0430436963 -------9.000 ono
DOMN8N is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 09:09 PM   #2
Hords
Treasure your balls?
Hords's Avatar
Unless you got a compact (bearing) puller it would be easier to remove the pump and replace the whole lot. Seen them on eBay for around $60 with the pulley included. Having said that, I replaced my water pump in Dec 05 and it didn't come with a pulley. Thought I would be able to remove the stock plastic one and swap it over. WRONG. In the end I got a steel one from Autopro. Put that in the oven on high for a while while the water pump shaft was sitting in ice. Still took a bit of force to get it on as it must be a decent interference fit. Still going good to the day. Hope this helps you a bit.
Cheers,
Rob
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
