Old 12-05-2007, 10:06 AM   #1
josh_hartman
Default More Trouble With BA Trans In AU :(
It is all put in and works well except for it doesnt change out of 3rd. It just stays in 3rd. Takes of in 3rd and does everything n 3rd. park, reverse and N work. any ideas? we got the cables caught in between the gearbox and engine when putting it up but didnt get to much pressure on it. easy way to say it is that i have gears
P
R
N
3
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 11:11 AM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
P
R
N
3
It's in Limp Home Mode, but that's about all I can tell you. sorry!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 03:12 PM   #3
bodes-sh
it would seem that more than likely the au ecu doesn't like the ba trans...haven't ba's got ion autos in them instead of btr's?
Old 12-05-2007, 03:40 PM   #4
josh_hartman
nah its a btr transmission. if i damaged the cables going to the trans would that put it in limp mode?
Old 12-05-2007, 03:54 PM   #5
peterban
AULTD
peterban's Avatar
Is your speedo working?
If not that also causes limp home mode
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 04:41 PM   #6
josh_hartman
yeh we put a speedo drive on the shaft so its all working
Old 12-05-2007, 09:25 PM   #7
peterban
AULTD
peterban's Avatar
The only other thing is maybe they changed the pinout on the transmission from AU to BA, but highly unlikely.
You could have been unlucky and damaged the wires.
Check that the plugs are in firmly, especially the large round one. It sounds as if the the easy ones on the inhibitor switch are O.K.
Old 12-05-2007, 09:39 PM   #8
bodes-sh
ba autos don't have a vss output on the trans, they get the reading from the abs sensors, that's why you don't have to get anything to adjust the speedo if you change to different wheels, it adjusts itself...apparently there's nowhere to put a speedo sensor in the trans itself
Old 12-05-2007, 09:48 PM   #9
peterban
AULTD
peterban's Avatar
I just read on the E series section that bad earths can also cause limp home mode to kick in.
I think the auto was modified so that it would take the speed sensor from the AU.
Old 12-05-2007, 09:54 PM   #10
Rollin
Rollin's Avatar
I'd like pics of the modded trans so show how the speed sensor is set up?
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 07:32 AM   #11
au2sw
Blown 5L coming
au2sw's Avatar
P
R
N
3
this may be your problem. you may not think there is too much pressure on it, but it may be enough to upset the pins at the plug, either making them loose, or pulling the plug out enough to lose contact. worse case sinario wires have broken. maybe lengthen the wires so they wont be strecthed tight and getting caught up on anything.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 06:07 PM   #12
just me
AU2 XR8
ba utes without abs have a speed sensor in them thats probally how he got away with it or he just put an older model extension housing on very easy i no there are some differences in grounding in the valve body on ba's compared to older models which will put it in limp mode try pulling the pan off and swapping your loom out of the au trans into the ba one it should plug straight just have to drop the valve body to get the ba loom out and put yours in reset the computer and see what happens hope that helps
cheers
just me is offline   Reply With Quote Multi-Quote with this Post
