Old 13-05-2007, 10:40 AM   #1
josh_hartman
Default How do i reset the ecu?
i need to know how to set the car back to factory setting so it can learn new things
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 11:13 AM   #2
JC
JC's Avatar
Disconnect the battery for 45 minutes or so, then reconnect it.
If you did a search for "reset" you would've found this in the results:
http://www.fordforums.com.au/showpos...10&postcount=5
Ford Performance Club ACT
Old 13-05-2007, 04:20 PM   #3
FGII-XR6
FGII-XR6's Avatar
a bit more to it than that once you reconnect it you need to do the following
1 start engine A/C on & idle 2 min
2 turn A/C off idle 2 Min
3 put in D A/C on idle 2 min
4 Turn A/C off idle 2 min
drive for 5 minutes changing speeds and throtle positions as much as possible
ECU is now reset but will learn further from your driving
Old 13-05-2007, 04:44 PM   #4
FS5
make sure you do not have the A/C on when you first start the car.
just refering to No 1 on your list.
start it first let it idle for a bit then turn it on.
this is probably what you ment anyway
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 05:29 PM   #5
FGII-XR6
FGII-XR6's Avatar
yes was just a bit unclear sorry follow everything in exact sequence and you'll be spot on so I really should have said start engine then switch A/C on etc
